Coming Home Lights Not Working
Rom Mar 22, 2013
  1. Rom
    Rom Member VCDS Map User
    443
    I've just Retro fitted the leaving / coming home lights mod.
    Coded it all in, leaving home works fine, so I assume the wiring side is fine, as it's only one wire.
    Coding wise, I followed the guide. Bytes 5 and 7 are checked, adaptation is set to 30 secs for both.
    The guide suggests they should just by starting engine, then turning off and removing key?
    So there's no minimum time of running before they will activate?
  2. monopole
    monopole Well-Known Member
    1,154
    466
    Was it dark out?
  3. Mikemc
    Mikemc Scooby Slayer VCDS Map User
    1,024
    37
    It doesn't matter if he doesn't have the auto lights, I retrofitted mine a week ago, and found that I had to earth the cable then wrap it up in insulated tape as it seemed to toggle itself off
  4. Rom
    443
    Don't have auto lights ^^
    The cable has a proper ring terminal crimped on, which is insulated. So there's no exsposed wire.
    The fact leaving home works, makes me think it's more a coding issue.
    I checked my module, it's high spec one, so that should be fine.
  5. L333fow
    L333fow Member
    66
    Just try activate the additional dis options, did that on mine and they started to work, it gives the option to adjust the times too
  6. Mikemc
    1,024
    37
    How do you do this mate? What section is it under?
  7. L333fow
    L333fow Member
    66
    No that I'm not sure on! I don't own vcds I have it done for me! I believe it's in central electronics (where the c/h & l/h options are)
    and into long coder and its either called dis addition features or dis comfort or something along them lines
  8. Mikemc
    1,024
    37
    Ok mate cheers ill have a browse later!
  9. mike foster
    3,967
    It depends what year your car is as to whether you have got the necessary control module. Look in central electrics for DIS additional features.
    I did Lee's for him and I forget what year his is but my 2006 sportback does not have the same facility. Anything before 2006 has no chance !
    Lee - why did you hit the dislike button on Mikemc's post ???
  10. L333fow
    L333fow Member
    66
    Didn't know I had actually! Thats what you get for quickly replying on iphone! How do i get rid?Mines 2007
    sorted it! Sorry about that
  11. mike foster
    3,967
    Nice one Lee - thought it might be a 'fatfingers' job !
  12. Rom
    443
    Well mines an 04. Dont remember seeing anything like that.
    I did find an option for something like lh/ch activation 0 = something 1 = something.
    But didnt look like I needed it, more for auto lights or something.
    I'll have a look tom when I get time. But did notice lh didnt work when I went to car after work, but did when I tried it once I was home.
    So I'll recheck the wire just to be sure.
  13. mike foster
    3,967
    Disconnect the wire and see if they work. If they don't then 'flash the wire to earth and try again.
    The system works on a ' toggle on - toggle off ' basis so the wire shouldn't be connected permanently. When it works just tape up the end of the wire and stash it. If you want to turn them off then flash it again.
    Your DIS will not have the additional options so you can't switch them on and off that way.
  14. Rom
    443
    So the wire doesnt need to be constantly earthed ? Just earthed once to activate / de activate the system ? Then you could disconnected, and it should remain working as described ?
  15. mike foster
    3,967
    Yeah - got it in one !
  16. Rom
    443
    Right. Disconnected the wire, nothing worked. Shorted it once. Leaving home works fine, everytime I've tried it. Before it had stopped working.
    Coming home is odd, the dipped flick on then off, and sides flash 3-5 times.
    Also side flash when I turn key on after leaving home is active.
    I have t8ps led sides, but no errors on dash, and they work for for leaving.
    Going to try disabling coming home if it's an option. See what that does.
  17. Rom
    443
    Still at a loss with this.
    Disconnected side lights incase they were the cause, dipped beams fllickered when key removed.
    For now ive disabled coming home.
    But even leaving home doesnt seem to work everytime i unlock the car.
    Wire is now disconnected.
    Any ideas ?
  18. OVRA3
    OVRA3 Well-Known Member
    1,079
    80
    The led side will always flash on start up as the car checks the lights. Interested in this as I want ch lh on my 2005 it's starting to seem like its not a goer
  19. Boon
    Boon Active Member
    441
    59
    I done this quite some time ago on mine - the mod. Works for both ch/lh 24/7 as I don't have the light sensor
    If you've followed the guide it should work... Have you checked the timing values in the adaptions? - sorry cant think of the adaption channel off hand
  20. OVRA3
    1,079
    80
    It seems hit and miss from what I've read must be getting the coding bang on
  21. Boon
    Boon Active Member
    441
    59
    The coding is the simplest part tbh, you just 'tick' the boxes
    iirc there are two boxes to tick for coming home & leaving home and the one for the light sensor needs to be left unchecked
  22. Rom
    443
    Yeah, i originally changed the value for leaving from 60 to 30, but also tried it back to 60 just to check.
    As it is now, ive only ticked leaving, as coming didnt work anyway. But obviously had them both ticked the first time.
    Light sensor is un checked still yeah.
    Ill plug it back in tom and write them down to be sure.
    I did follow the guide, which is why im a bit confused. I just been out to pick gf, unlocked car, and nothing came on.
    Came home, locked it, just tried as i type this, and they came on. Is there a limit, or something ? As ealier i had locked unlocked locked unlocked over and over. Should they come on everytime i unlock ? Or does it need to be cycled, like ignition on to reset before they will come on again etc ?
  23. Mikemc
    1,024
    37
    When opening the car with the unlock button, for me, it will continually activate the lights, but when getting out the car and locking works just the once after turning engine off
  24. Boon
    Boon Active Member
    441
    59
    Yes mine work just the same
    Have you had any problems with the drivers door? As opening this also activates/disables the timer and turns lights on or off respectively. It may be thinking that the door has been opened?
  25. Rom
    443
    I was trying the coming home with the door open mostly :ninja: Though i did try it once incase it mattered.
    Not had any issues with the drivers door at all, with regards to locking, window etc.
    I thought maybe i was upsetting it by locking / unlocking so much. And maybe thats why it worked after it had been kind if reset after a drive.
  26. Rom
    443
    Ive never noticed this before, though in all honesty, ive never looked.
    But how does it know it had LED? As they should be normal 501 bulbs. I thought the test procedure it done was more based on resistance ? If resistance is out of spec, but is faulty, and error comes up.
  27. OVRA3
    1,079
    80
    I think it's because they need so little power.. Mine flash about 5 tomes on start up.. Looks coooool ;-)
  28. NHN
    29,281
    1,692
    That's cold diagnosis for you with led's :)
  29. Mikemc
    1,024
    37
    The only time my lights go off is when I open the door after unlocking it, or obviously the time elapses
  30. Rom
    443
    Think I'm officially beaten.
    I give up.
    Ch will not work, not matter what I do. Lh will work sometimes.
    If I unlock, and it doest work, if i keep locking and unlocking, eventually they come on.
    Ho hum. So much for a simple mod :)
  31. theo289
    theo289 Member
    293
    i've got an audi a3 tdi 2007 sportback - could the leaving lights be coded on this?
    Thanks!
  32. Mikemc
    1,024
    37
    It worked for me on a 55, I'm sure after a certain year it's not so easy? Ill try find the thread I used
  33. Topon87
    Topon87 New Member
    Does any one no if this product will work on a audi a3, automatic head light kit? TYPE THIS IN ON EBAY!!
    (OEM VW Auto Automatic Headlight Sensor and Controller Golf Jetta Passat EOS
    Watch)
    audi do is part of vw group
