Hi All,
I have a slight leak from the cam adjuster gasket, so I thought I would replace it while i'm there might as well do the cam cover gasket. Anyway last night I managed to get the cam cover off give it a good clean up and powder coated it black.
but i'm stuck,
How do I get to the cam adjuster gasket is there a easy way of doing it. Elsawin wants me to start moving the timing belt so the vavles are in a certain position then move the cams in to another position and remove the chain and lift the assembly out. can I do this with out removing the chain.....
Also do you think i should put a coat of Clear Lacquer on top of the powder coat for easy of cleaning later on?
any help will be great. here are some pics so far more to come.
but i'm stuck,
