I've enabled code 62 comfort functions by using recode 7931.
I've modified the default value of channel 62 from 204 to 207 ( adding bit 1&2)which should enable the windows to wind down and up via the keyfob.
when all is saved and disconnected , i lock the car .. then unlock by holding the open button on the keyfob for more than 3 seconds .. The windows do indeed open but only drop 5 inches then stop. Holding the lock button the windows should then close .. but they dont.
The code of 207 tests correctly
Is there anything i can do to get the windows right down ?
putting the key in the door still opens and closes the windows as expected
cheers
cheers
