B5 RS4 Bumper onto B5 S4....
Jimmy Oldskool Feb 20, 2010
  1. Jimmy Oldskool
    Jimmy Oldskool New Member
    Hi guys.
    I've just bought an RS4 bumper for my S4, but it looks really different at the side mounts??? :huh:
    Does anyone know of a 'How to' guide or has anyone done it and prepared to help me out??? :confused:
    Jimmy
  2. aragorn
    17,954
    701
    i'd imagine it would use the much smaller facelift side mounts, (the S4 bumper uses the larger, older pre-facelift style) but i've no idea how fitment would be with it being a widebody bumper.
  3. diffas
    diffas Member
    152
    23
  4. andybnwc
    andybnwc Member
    752
    heat and bend it its fine i need one
  5. diffas
    diffas Member
    152
    23
    You do that heating and post results. ;)
  6. andybnwc
    andybnwc Member
    752
    People do it all the time only bad bit is the bottom bit bulges a little some people brace it others just mod it the inner ali bit has to be bent too . What you doing with the s4 bumper?
  7. sparkyvw
    sparkyvw New Member
    jimmy message me over on edition38 if you need help fitting. I have a rs4 bumper on my s4.
  8. slepy
    slepy Extremely smart and handsome person. VCDS Map User
    2,082
    316
    Isn't it better to get rieger (or similar) RS4 type bumper? Wouldn't it fit better?
  9. adamss24
    adamss24 Well-Known Member
    4,557
    394
    Rieger its ok but the stock rs grilles dont fit and the mesh they supply looks a bit gash. The Dietrich one is a perfect fit and takes rs4 grilles but it's made of fibreglass so not that strong than ABS plastic or PuRim...
  10. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    made a good job of that but it does look a bit funny at the bottom corners
    I gutted the centre spars out of my S4 front bumper to make three larger vents....bigger than the RS4 ones but without the gills
