B5 1,8 SE Breaking...
Siena Mar 5, 2009
  1. Siena
    Siena Active Member
    2,626
    As in the topic.
    It's an SE model, and has climate, though Byzan's got first dibs at the compressor.
    All panels are straight and clean, has 5 OEM 15" alloys, instrument cluster with extra gauges - volts and oil temp, but no DIS.
    I drove her back from Bexleyheath yesterday, drove fine, though has clunking from the front, which is of course control arms.
    Everything bar the manual tranny, driveshafts, flywheel, pedal box, master / slave cylinders, selector mechanism, centre console trim and starter motor are available.
    I'll post up pictures shortly - not sure if it's Ming Blue, or some other shade.
  2. Siena
    Siena Active Member
    2,626
    A few pictures...
  3. Broken Byzan
    13,237
    466
    Hands off the compressor guys she's mine :salute:
  4. Siena
    Siena Active Member
    2,626
    ^^^ Lol. That's got your name on it, it won't be sold to anyone else.
  5. liam_mcf
    liam_mcf New Member
    23
    Does the ICM fit the 1.8t? :)
  6. aragorn
    18,605
    871
    yup afaik its the same part.
  7. Siena
    Siena Active Member
    2,626
    What's an ICM? Forgive my ignorance, been a long day.
  8. aragorn
    18,605
    871
    aka ignition amp or ignition power stage...
  9. Siena
    Siena Active Member
    2,626
    Ah, got you. Ignition Control Module.
  10. Markey
    Markey Active Member
    2,175
    Will the power steering rack and pump fit my 1.8t?
  11. d4mo
    d4mo Member
    100
    Does it have a black centre rear ashtray and diagnostic cover? if so then im interested as mine is missing.
  12. Siena
    Siena Active Member
    2,626
    PAS rack will fit your 1,8T fine, part number's are the same.
    And, it's leak free.
  13. Siena
    Siena Active Member
    2,626
    Unfortunately, the ashtray has a bust hinge, and the OBD cover's missing.
  14. d4mo
    d4mo Member
    100
    Ok cheers Siena, I'll keep looking, Audi quoted me £125 for a new one!!
  15. H2o-uk
    H2o-uk Member
    106
    Siena, does it still have the caps from the mats that clip into the studs that come off the carpet, if so can I have them :)
  16. Siena
    Siena Active Member
    2,626
    Will check for the studs - they're obsolete new, went NLA in December 2007.
  17. simon1303
    simon1303 Member
    42
    has it got a front centre arm rest at all?
    im only really after the lid
    Si
  18. Siena
    Siena Active Member
    2,626
    Simon, no front centre armrest on this model.
  19. H2o-uk
    H2o-uk Member
    106
    Any further news on the mat locator tops ? Also, are the wing mirrors electric and heated and if so how much would you want for the passenger side as Ive noticed theres a hole in the triangular bit that bolts to the car on mine, looks like when its been folded back its cracked a chunk off. I'm also assuming that my existing colour coded panel from my current wing mirror would just screw in place of the non coloured panel.
  20. Siena
    Siena Active Member
    2,626
    H2o-uk: PM sent.
  21. Markey
    2,175
    How much?
  22. andybnwc
    andybnwc Member
    752
    are the mirrors colour coded? is the drivers front wing ok and if so are they easy to change?
    thanks
  23. Siena
    Siena Active Member
    2,626
    PAS rack £67 including postage.
  24. Siena
    Siena Active Member
    2,626
    Mirrors are not color coded, so will need painting to match a higher-spec car.
    Driver's side wing is in good shape, no dents or grazes.
    Not hard to replace, front bumper needs to come off though, to gain access to the concealed bolts.
