Audi s3 PCV failure
doughty29 Jan 2, 2013
  1. doughty29
    doughty29 Member
    110
    hi guys, i belive that my PCV Valve isnt working due to air pushing out of my oil filler cap when removed, is there an up-market/ after market one i can put on my car? any ideas, cheers
  2. Vex182
    Vex182 Guess what I drive...
    1,035
    79
    All in the stickys at the top of the forum mate.
  3. <tuffty/>
    20,890
    3,701
    No after market valve as such dude... just replace all the split/worn bits... or do a PCV delete..
    For the pressure to be pushing the oil cap up then something is seriously blocked and/or you have some bad ring wear.... you can test the theory by undoing the PCV pipe from the top of the rocker... see if the engine is breathing heavy...
    This is the stuff under the inlet of a facelift S3...
  4. ceS3r
    ceS3r Member
    95
    My oil cap also pushes up when its loose, so I will surely do the PCV delete..
