abs fault
kkk
North London
My abs light is on and has a fault for the pump
Could the pump cause an intrrmittant but there more than not vibrating throught the pedal wheel snd car?
I need to replace the pump anyway but want to know if il need discs aswell.
My abs light is on and has a fault for the pump Could the pump cause an intrrmittant but there more than not vibrating throught the pedal wheel snd car? I need to replace the pump anyway but want to know if il need discs aswell. Thanks
Hi there, have you managed to repair the problem? If not let me know, it might be the abs module, i had the same issue and it was the module itself. I can repair it if you require.
Have you had it scanned for faults? I had a similar issue and the problem turned out to be a wheel speed sensor fault. A much cheaper fix than a new abs pump
the fault comes up as a pump issue and googling leads to be the wireing, fuses or the pump and i checked the wireing and fuses.
i have a pulsating pedel but not all the time which leads me to believe it is the pump bearings causeing this.
838
591
999
22
