A4 B8 Foglight bulb
johno5 Jan 16, 2013
  1. johno5
    johno5 New Member
    Can anyone tell me how to remove the Fog lights on my 58 plate A4 B8 S Line. So I can replace a broken bulb, Stealers want a small fortune. would be grateful for any info Please.
  2. NHN
    29,284
    1,695
    Foglights do you mean?
  3. johno5
    johno5 New Member
    Yes fog not spot, Sorry.
  4. NHN
    29,284
    1,695
    Pull the fog trim of 1st & then its screwed onto the bumper, simple job & remove bulb from rear.
  5. johno5
    johno5 New Member
    Cheers, Ill have a go this weekend. Thanks
  6. scoTTy
    scoTTy Active Member
    1,962
    Be careful in cold weather like this. It's probably worth warming the grill plastic with a hair drier first.
    A few people have snapped the tags off. The other way is that apparently you can get to them via the wheel arch if you move the liner out of the way....although I just grabbed and yanked the grill (in warm weather).
  7. redspudder
    redspudder Sparky
    371
    I found it easier to go in through the wheel arch,turn your wheel so you have access and then remove x2 torkscrews from the inner arch lining and then bend it back enough to fit your arm in,the power connecter has a small indent to push to release it from the lamp holder,once this is removed twist the holder and it will come out in your hand with the lamp attached,the new unit should come with the small holder and lamp attached and then just reverse the process.
    I changed mine for white fogs a few moths back to match the xenons and DRL's.
  8. toadusmodus
    toadusmodus Member Team Scuba Audi A4
    37
    Ooh. Do you have a link for the what bulb you replaced with? I think my wagon looks a bid naff having 'yellow' foglights, and nice white headlights!
  9. riggssuzuki
    riggssuzuki Active Member
    496
    57
    White fogs are great for 'the look' but yellow beams cut the fog much much better.
  10. johno5
    johno5 New Member
    Didn't need to replace the fog light bulb, when I removed the wheel arch protector I found out that the bulb & the holder had not been replaced properly from having the cam belt done last month. The bulb was still working & very worryingly for the last month I've been smelling burning plastic as I use the Go home lights this time of year. So I've found the source of the smell ( the hot bulb resting on the plastic) & fixed the bulb for free. Wish most repairs where this simple.
  11. NHN
    29,284
    1,695
    Damn, thats nasty, easy fix though huh.
  12. johno5
    johno5 New Member
    Thanks for all the info everyone.
