A3 power steering rack - part number help
Evan K. Michaels Oct 8, 2011
  1. Evan K. Michaels
    Evan K. Michaels New Member
    hello
    first of all, hi to everyone, i am new to your forum.
    i urgently need some help, my A3 needs a new steering rack but i need to find out the part number of one fitted in my car so i can source the right part.
    can anyone please help me get this from my chassis number and maybe suggest a place i can find one?
    thank you a million
    regards
    Evan
  2. Sandra
    Sandra Administrator Staff Member Administrator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter
    26,654
    9,646
    Hi Evan, welcome to the forum. You could try pm either user khufu or nhn on here. I know they have access to part numbers. Hope it
    helps you.
  3. Evan K. Michaels
    hello Sandra, thanks for the suggestion, i am afraid i can't send PM, i am new to the forum. hopefully they will read my post and respond. regards
    Evan
  4. Khufu
    Khufu Well-Known Member
    5,704
    31
    What car/year do you have? Are your going for a 2nd hand one or a new one? IIRC there are two main types, they changed the design over the years and the two arent direct replacements without some modifications. I'm sure NHN has has some dealings with this.
  5. Evan K. Michaels
    hello Khufu, i am pleased you picked this post. i am looking preferably for a second hand one.
    my car is an A3 2.0 FSI (2004 model) vin is [FONT=Calibri, Verdana, Helvetica, Arial]WAUZZZ 8P14A029412 [/FONT]
    i really appreciate your help
    regards
    Evan
  6. Adam.
    Adam. Meow.
    662
    34
    What's your engine code?
  7. Evan K. Michaels
    Hello Adam, i hope you are well.
    my [FONT=Calibri, Verdana, Helvetica, Arial]engine number is AXW005520[/FONT]
    cheers
    Evan
  8. Adam.
    Adam. Meow.
    662
    34
    Silly question but are you in a lhd or rhd car? lol
  9. Evan K. Michaels
    it was a rhd last time i drove it! LOL
  10. Khufu
    5,704
    31
    same car as mine..... will have a look on other PC.
  11. Khufu
    5,704
    31
    ETKA seems to go more by VIN number, but what you will have is a generation 1 rack but the danger in getting another matching gen 1 rack is it will fail the same (hence the changes). Hopefully Nigel (NHN) may be on & provide a bit more info on the matter.
  12. Evan K. Michaels
    hello khufu, i really appreciate you looked into this thanks for the information, i see what you mean, i hope nigel can provide a bit more information.
    can you let me know what's the part number in case i have to source the gen 1 rack?
    regards
    Evan
  13. danny_s3
    danny_s3 Member
    234
    [FONT=Tahoma, Calibri, Verdana, Geneva, sans-serif]I have just had this problem and it turns out I have got to replace the rack and electic pump,
    Audi want around 850 for this!!!
    the problem is finding one that matches my part number 1k2423051ac.
    Can find them on
    ebay but not with ac at the end[/FONT]
  14. mike foster
    3,967
    That part number was replaced on 01/04/2006 with no direct part number. Need to know what engine you have in order to provide part number. If it's a BKD engine the part is :- 1K0 199 313 H priced at £231
  15. danny_s3
    danny_s3 Member
    234
    Hi there mike thanks for the quick reply , my car is a 53 plate with a 2.0 tdi engine in Am I right in saying some of these units are 3 plug and others are 2 plug , thanks dan
  16. mike foster
    3,967
    Yes 2 pin and 3 pin. Unfortunately things are a bit more complicated than I first thought. The number I gave you was the ' assembly carrier'. If you need the whole thing you will have to go to Audi to check against chassis number exactly which parts are required. The whole unit is available as part-ex but I'm afraid it's very expensive. £863 at the last count.
    Sorry if I built you up but it very much depends on what bits you need and which ones are available separately. Just after your reg. they changed the rack design but I can't tell exactly which bits you need. Sorry !!
