A3 key fob - can I replace the external case?
Minstadave
I have the older style rounded key fob, is it possible/easy to buy a replacement part off ebay and switch the blade and electrics over?
Mine has got tatty over the years.
Can you take a photo of your key? So long as you swap transponder over and resync if its a remote should be ok. My new key was about 40 complete though.
The immo chip is in the top half & its glued in place, you could remove, but risk breaking the glass, your choice but overall yes its possible to swap parts across & if you swap the pcb over within a limited number of minutes, it should hold the remote settings, anything afterwards & needs resyncing with vcds ideally.
Yep as NHN says, the glass chip is easy to break, personally i would use this as an opertunity to buy a new extra key and keep the tatty key as a functional spare.
hi can I use the new style remote with the old style internals ?
