i would imagine it will be cast into one of the spokes on the back of the rim, actually if the avus ones arfe what im thinking (s4 fitment 17s) it may be behind the centre cap around the bolts
PCD is the Pitch Circle Diameter of the bolt holes. ie 5x100 is 5 bolt holes evenly spaced around a circle of 100mm diameter.
Offset is the distance from the centreline of the wheel to the mounting face. Usually a smaller Offset will make a wheel sit further out than one with a larger offset.
