A3 8P 53 plate 2.0 tdi 140 - Using coolant?
RobMorris Jan 23, 2012
  1. RobMorris
    RobMorris Member
    539
    10
    Chaps
    I seem to be losing/using coolant?
    From max to min is only a small amount but it drops from max to min over about 3 weeks and then i have to top up again..
    Assume this is not normal?
    I cant see any leaks/splits?
    What say you?
  2. Khufu
    Khufu Well-Known Member
    5,704
    31
    sadly it is all to normal for the early tdi engine. Try a search on the forum for all the issues. Hopefully its not a porous cylinder head.
  3. RobMorris
    RobMorris Member
    539
    10
    cheers - i did do a search but didnt find anything
    il try different keywords to grab some info
    and indeed i hope its not a porous head (not that i know what the means - but it sounds bad!)
  4. MTRL
    MTRL Split Grill!
    459
    52
    Have you checked your oil cap for a milky substance or residue?
  5. FranA3
    FranA3 FMDETAILING Site Sponsor Regional Rep Gold Supporter Team Brill Red Audi A3
    7,264
    363
    sounds like the dreaded cylinder head
  6. mike foster
    3,967
    Rob, I'm sorry to say it is almost certainly the 'porous head' problem which was a common problem on the pre 2005 140 BKD engines.
    A fault in the head manufacture caused the metal to become porous between the coolant channels and the cylinders and the coolant was evaporated away. This problem was never acknowledged by Audi even though the subsequent heads were improved which cured the problem.
    The only real cure is to get a later model cylinder head fitted but you could try a temporary fix which has helped others. Buy a bottle of K-Seal from Halfords or similar and bung it straight into the top up bottle and run the car until hot. It cost less than a tenner and might help. Got to be worth a try anyway !
    Good luck mate and I hope I'm wrong with the diagnosis !
  7. flying oyster
    flying oyster flying oyster
    563
    27
    check rad at bottom corners
  8. NHN
    29,577
    1,779
    Also check coolant hoses as age can deteriorate, egr cooler is common, as oyster states rad, various things to check before condemning head, but thats also a big possibility.
  9. Pipsqueak
    Pipsqueak Member
    137
    I've noticed a smell of coolant when I get out of the car after a drive particularly on a warm day. Theres no sign of a leak and the coolant level doesn't seem to be going down. Could this have something todo with the head?? It's been bugging me since i got the car. It's a BKD. Any insight would be appreciated
  10. WALTO TDI
    WALTO TDI Member
    293
    12
    ive had this same problem. had the head pressure tested and no leaks were found. after driving about 60 miles coolant warning light illuminates on the dash. i decided to do one last thing before taking it to the garage for full strip down and inspection. i used a well known leak stopper in the header tank. i have now driven around for over 400 miles and not had to top the coolant up once. im assuming that there must of been a small leak from either the radiator or waterpump. i could not see any leaks or water on the ground, i had no signs of water in the oil and there was no condensation out of the exhaust. have a look for any of these tell tale signs mate.
  11. Pipsqueak
    Pipsqueak Member
    137
    Maybe a daft question but is there a time by which a BKD engine will show up a porous head i.e. if the engine is 7 years old and hasn't gone then it will be OK or is it after a certain amount of miles.Was it 2003 - early 2004 engines or was it later than that too? Pretty curious now.
  12. Pipsqueak
    Pipsqueak Member
    137
    Forgot to add how do you find out if it's a BKD 'A' or a BKD 'B'. Apparantly Bs are OK
  13. mike foster
    3,967
    Take the engine cover off and look behind the fuel injector pipes. You should see a number with the suffix 'A' or 'B'
    I have an August 2005 reg, Model Year 2006 sportback which has suffix 'B' and is fine.
  14. Pipsqueak
    Pipsqueak Member
    137
    Cheers i'll have a look.
  15. Johnny Bravo
    Johnny Bravo 6+1 Gears Audi A3
    898
    70
  16. RobMorris
    RobMorris Member
    539
    10
    I couldnt see any problems so I bought a bottle of K-Seal so will report back after a couple of weeks and let you know if it has worked for me!
    BTW what is the cooling system capicity? if over 23 litres I need a second bottle of K-Seal..
  17. flying oyster
    563
    27
    only one will do hope it works for you had same problem last year but since having the waterpump changed when i had cambelt done all seems fine
    kseal was a good temp fix at the time for me
  18. RobMorris
    RobMorris Member
    539
    10
    kseal claim it to be a permanant fix? only requiring another bottle if you do a full drain and re-fill? (which ive never done in my life!)
  19. flying oyster
    563
    27
    i can only speak for myself mine worked for a while then i got loss of coolant again but since water pump done and car serviced its been fine without kseal in it
    there are plenty of guys on here that have used it on here and have been more than happy with it
  20. Graham89
    Graham89 Derv Perv
    310
    I had the dreaded porous head issue. K seal and over 20k miles later it's not dropped at all.
  21. RobMorris
    RobMorris Member
    539
    10
    I pray for the same!
  22. RobMorris
    RobMorris Member
    539
    10
    Little late with my up date, but perhaps better as ive done about 3k and I can say the K-Seal has worked a treat.
    Not dropped a single drop since adding it to the coolantk. It was instant magic.
  23. - Jrd -
    - Jrd - Member
    107
    Worth the £12 then, Good stuff
  24. Bramley
    Bramley Member
    389
    19
    I have exactly the same problem but mine has some condensation - white smoke coming out of the exhaust, is this a cause for cocnern?
  25. mike foster
    3,967
    You can try K-seal, it can't do any harm.
    White smoke indicates it is likely to be the porous head situation I'm afraid.
  26. adamroutley
    adamroutley Member
    58
    So many people are quick to say "cylinder head"...mine was leaking coolant slightly..turned out it was the Radiator. Needless to say, after researching on here before hand I was SH*TTING myself!
  27. mike foster
    3,967
    Adam - leaking rad does not produce condensation and white smoke !!!!!!
  28. adamroutley
    adamroutley Member
    58
    Original post has no mention of this :meeting:
  29. mike foster
    3,967
    I was answering post #24 !
  30. adamroutley
    adamroutley Member
    58
    well just for clarification, I was answering the original question asked as it was HIS thread. I made no mention to, or referred to in any way post #24 so whats your problem?
    Back to the original question..
    Go get it jacked up pal and searched :yes:
  31. mike foster
    3,967
    I don't have a problem Adam. The op (Rob Morris) reported back to the forum in post #22 that it was all sorted. Therefore no need for any further reply from you or anybody else to the original question !
    Then Bramley came in with a supplementary question in post #24 to which I replied.
    End of !
  32. NHN
    29,577
    1,779
    Then, as a suggestion, maybe next time you should follow Mike's quite correct suit & quote the post you're replying to, rather than random input after another party has also posted with same issues, therefore avoiding confusion.
    Mike doesnt have a problem, he is purely helping other members without a hint of animosity, so please also do so yourself, there is no problem, therefore dont create one thanks :)
  33. adamroutley
    adamroutley Member
    58
    Thats the thing NHN my first post quoted all the people I was replying to, i was simply trying to make the OP feel a little better in the sense that it MIGHT NOT be the head. (a point yourself highlighted)
    At that point Mike foster got on his high horse assuming that my reply was directed at him personally which led to this quote below.
    i was merely defending myself.
    ive heard on many forums that this one is specifically clique'y and pedantic, and your going to "stick up" for people with more posts but i was simply providing the OP with a DIFFERENT result to what everybody seems to quickly state.
  34. NHN
    29,577
    1,779
    Whereas I appreciate the point you're making about it may not be the worst case scenario, you were actually adding info relative to the OP's post, hence why a simple quoted remark would help to clarify the comments you were directing your reply to, Mike added info that was relative, he had no malice in his intent.
    Butttt, you instigated a responce by posting "so whats your problem" which 99.999% of people on any forum would take as directed towards the other party in discussion, not the whole forum, you had no need to defend yourself as there was no friction directed towards yourself that I can see, ATM.
    I would also point out, if you had made that comment on any forum, I suspect you would have got the same responce, which unless I read it wrong Mike also gave a fair, factual & non friction like responce, so from my POV you've opened the door for a problem to arise, unneccessarily may I add.
    As for the comment of ASN being very clique, pedantic along with more support for long standing members, totally unnecessarily, just adds attention to you for all the wrong reasons from all the wrong people, if you want to enjoy the forum & get along with everyone, which most are a great bunch of people, then forget whats happened thus far & change your attitude.
    mozza1202 and RobMorris like this.
  35. Bramley
    Bramley Member
    389
    19
    Audi have said my egr cooler is leaking
