A3 2.0 tdi, eratic idle sounds choppy once warm
chrisy t Sep 8, 2011
  1. chrisy t
    chrisy t Member
    132
    Hi guys, i have ownd my A3 now for nearly a year and since i bought it, it has always idled funny, it sounds great at first but as soon as the engine warms up, the engine starts actinc eratic, it almost sounds like it could cut out, but the car drive fines, only recently i have noticed it goes in to limp mode sometimes, when i thrash the car it loses all its power and i have to turn it off and back on again to get the power back? Do you think its related, any ideas?
    Chris
  2. devonmikeyboy
    devonmikeyboy As far from JBS as possible !
    1,245
    PD140 engine has a ruff idle on tick over. To sort it just rise the rpm by a few hundred on VCDS . Limp mode could be anything. Get the car scanned to find out.
  3. vw754
    vw754 vorsprung Durch Technik
    2,324
    58
    sorry my car dont idle rough,smooth as silk,and the rev gauge dont even jump a bit...100% perfect!........diagnostics first then see what fault codes you get.......ive heard it can be the wiring loom that runs through the cylinder head.
  4. vw754
    2,324
    58
    mine did that ,it was sticky turbo vanes........my friend remapped mine after a good thrashing down the a road.........never did it again,had the map taken off after ten minutes as the map wasnt specificaly for my a3,never had the issue again.......been ok for the last year or so.
  5. TimG
    TimG Active Member
    942
    45
    COuld be related to the temp sender. Wiki ross says irratic idle is a symptom.
  6. chrisy t
    chrisy t Member
    132
    Cheers, gunna get it scanned and see what it comes up with! I thought the limp mde might have been related to the MAF sensor or something? I have also noticed a little oil in the intercooler behind the bumper? Is thios normal?
    Chris
  7. vw754
    2,324
    58
    oil in itercooler is normal.a faulty temp sensor wont show as a fault check what temp its reading on the diag machine when your cars at normal operating temp
  8. chrisy t
    chrisy t Member
    132
    It always sticks dead on the centre, it never moves, once it warms up it just stays in the middle! Why does oil collect in the intercooler?
    Regards
    Chris
  9. vw754
    2,324
    58
    pm sent!
  10. chris11122
    chris11122 Member
    50
    10
    Mine has an erratic idle occasionally and the temp gauge is perfect - am i missing something... I also have VCDS and haven't found a magic cure yet....
    Any help welcome, it does annoy me!
  11. TimG
    TimG Active Member
    942
    45
    It will dude, I have that fault code on mine a couple months back. Had it on my S3 too!
  12. vw754
    2,324
    58
    NO IT WONT cuz if its reading low........its still working but giving the ecu a wrong reading,if it totally stops working then it will show as a fault......im sure somebody will back me up very soon.........but then hey i only do this for a living so might be wrong.
  13. tdi-man
    tdi-man Well-Known Member
    1,783
    64
    WARM IDLE FAULT IS A COMMON FAULT .
    FUELING NEEDS TO BE TURNED UP ON IDLE TO FIX OR TURN IDLE UP IN VAG COM
