Hi Guys
As the title suggests I'm a new owner (or returning owner as I had an A3 1.8TS Quattro about 6 years ago) I've been a member on other forums for my other cars so I'm hoping things are as helpful here!
I picked up a 1.8 t sport Quattro for £2600 on a 51 plate (2002) via a private sale. The car looked in good condition, no obvious signs of engine troubles (120k on the clock), new(ish) p-zero's all round....guy said he'd lost his job so had to sell. 12 months MOT, one advisory regarding a light misting of oil on the O/S/F shock (which knocked a fair bit). Ad said car was in A1 condition and the guy seemed genuine.......test drive was fine (turbo had a little lag nothing untoward). He confirmed no electrical issues or head gasket problems.
5 miles from the house and after putting petrol in (it had about 60 miles fuel left during the test drive) I noticed the temp gauge had gone off the scale (it was sitting in a normal position during the test drive and the MOT emission test said temp gauge showed warm engine).....5 miles later overheating warning light...pulled over popped the bonnet and a bit of steam (in the p*ssing rain). Phoned the guy and he admitted the temp gauge was broken and never moves unless you put a full tank of petrol in(despite assuring me there were no electrical issues) he then admitted the water pump was probably faulty.....got it into my local VAG specialist (500 metres from my house!)....and it turned out the following is wrong:
Instrument cluster temp + fuel gauge is faulty
o/s/f shock absorber is leaking heavily
Front pads and disc are low recheck in 3-4k
Rear anti roll bar collars are spilt
Exhaust hanger bracket missing from centre box
o/s/f wish bone rear bush is torn
Front anti roll bar collars is split
Cam cover gasket leaking
All wipers are in poor condition
Indicator bulbs at rear are starting to go white
Poor water circulation is causing over heating (cause might be water pump not changed with cambelt service)
I've called the MOT place as the car has done 200 miles since the MOT and it shouldn't have passed! My firm is retained to prosecute on behalf of VOSA so I've called the garage and had a 'nice chat'.....they want to check things out to see what they think was 'missed' on the MOT and come to some arrangement....I'm fixing the water pump and doing a new cambelt at the same time....just wondered how much the other stuff might cost? If the ARB collars have split do I need new ARBs?
Russell
Russell
