A little update on my rebuild
Andrew@A.L.D Jul 7, 2012
  1. Andrew@A.L.D
    3,877
    617
    After my bad news on the dyno with the rings and glazed bored the engine was put back together with new parts and modifications like rings, a deglaze, 4 bar reg, piper cams and a ported 0.82 a/r exhaust housing.
    last week i managed to get it running but when i revved it it went pop and stopped, I did a compression test and all were well down? Timing looked spot on on the cam pulley and etc? ok off with the head again as i thought i bent some valves but no everything mint? I take the Cat cams pulley off to find this
    Bloody keyway has snapped and the pulley moved on the cams
    To say i'm lucky not to of bent any valves is a miracle
    New Piper cams pulley on its way
    Also been offered some ID 1000cc injectors that i'm very tempted to get at a good price but hey will see how she goes with this rebuild first
  2. JtotheD
    JtotheD Active Member
    907
    26
    i'd say! good luck though!
  3. Prawn
    11,456
    3,353
    Jesus christ Andrew, could you have any more bad luck?
    It's such a shame to see such a mega spec build tortured by stupid little problems that COULD effect any of us, yet they all seem to effect you!
    Poor git, all the best with getting it back together AGAIN! Still looking forward to the results!
  4. <tuffty/>
    21,013
    3,776
    Turning the engine over using the cam pulley bolt can cause this... the supplied key is a small little bugger from what I remember too so not a good start :(
    Bad news dude, not having much luck but then this type of build is always subject to these little hiccups... been there bud...
  5. Andrew@A.L.D
    3,877
    617
    Doesn't bother me as its all part of the problems with going BT and it could of been a lot worse so i'm happy its just a new pulley needed and not a pulley and new valves.
    Never turned the engine over with the cam bolt, always the crank bolts so not sure why its happened but i'm glad i found this problem anyway before i bent any valves or damage any pistons
    The keyway in the Cat cams pulleys are quite poor i would say compared to others i've seen so i hope Piper ones are better and stronger
    I'll get there with it
  6. StaceyS3
    StaceyS3 Well-Known Member
    2,491
    483
    Sorry to hear the news mate not had much luck :(
    But on the other hand was rather lucky valves and pistons are unscathed
    Can't wait to see your results when it's finished as I'm sure it will be a weapon ;)
  7. <tuffty/>
    21,013
    3,776
  8. Andrew@A.L.D
    3,877
    617
    They are but I need one sooner so ordered a piper one
    I would of got a ie one as they sexy but we have to cover them up anyway
  9. MUSH
    MUSH MUSH Developments Ltd.
    713
    12
    Bummer mate, but thats development i suppose.
    Good luck with it, you will have it sorted soon no doubt.
  10. badger5
    9,429
    1,974
    the supplied pos thing from catcams is a joke.
    mines doweled as it was obvious the supplied thing was inadequate
    did yours looks like 1/2 a woodruf key looking like it was snapped in half when you got yours? mine was.. it was one of those wtf moments when you looked at it..
    when you due back to the dyno next?
    got your uber injectors ready for the big mapping session?
    going to be a monstor (hopefully without more drama's)
  11. Andrew@A.L.D
    3,877
    617
    It looked like a hollow dowel and when i look at it now i think why did they fit that bit of s**t !! As said i hope piper one is better
    I've yet to put it back together ( shouldn't take long, i can get the head off it now within a hour now ) but first i will take a break for 2 weeks in the sun from the 26th so maybe september ?
    I think i will stick with the 870cc and just fit a 4 bar to see how it goes
  12. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    very lucky & unlucky....the power this beast will pull, it was probably a god send it did it on tick over .....
  13. Welly
    Welly VX220 SC Driver :)
    10,696
    127
    Jesus, no-one likes to see that mate. HOW did you get away with it?? Good luck skills there!!
  14. Andrew@A.L.D
    3,877
    617
    I got away with it as it snapped the pulley turned clockwise and gripping the bolt as it went
    The bolt was really tight to undo
  15. Andrew@A.L.D
    3,877
    617
    I have canceled my order for the piper cam pulley and fixed the one i have by drilling out the crappy dowel and fitting a solid one
    I have also drilled out the M6 locking bolts and drilled and tapped them to M8 as the M6 threads were screwed.
