airbag problem
swine
cork
took off the steering wheel today, when i put it back on i got an airbag light on the dash, did a scan with vagcom no error codes, tried to connect to airbag module and it said no response from controller, any ideas
Did you touch anything at the back of the column as you may have disturbed the wiring to the steering cu, does your horn work, is it an mfsw & if so do the controls work, is it tip if so do the paddles work.
1 idea, unplug the battery for 10 minutes, then plug back in & check for errors thrown.
thanks for reply, horn works, no mfsw, and no paddles, disconnected battery for an hour last night, did a scan after and no fault codes relating to airbag, steering, instruments or abs, still won't communicate with controller
Huh, but you still have full functions of the stalks for headlights, wipers, indicators etc?
Everything works just the airbag light on dash and no response from controller did notice when I started it yesterday 3 beeps from behind me somewhere
really stuck now, is the controller knackered, anyone have any ideas
If you go into the steering module 16 & 17, check Fault Codes, does it show anything there?
What did I read recently about the airbag module access, urrmm if I recap I'll post.
Have got me then mate, as never had this come up & neither has my mate with an A4 after taking airbag of even with battery connected still.
Can you post a scan of your car on here please.
Tuesday,01,June,2010,13:10:16:22088
VCDS Version: Release 908.2
Data version: 20100326
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: Mileage: 186560km/115923miles
Address 01: Engine Labels: 059-907-401-AKE.lbl
Part No: 8E0 907 401 C
Component: 2.5L V6 TDI G000SG 0004
Coding: 02015
Shop #: WSC 28049
Part No: 00002059
Component: 130 106LC150_1.V77541536186
AUZ6Z0A0119152
No fault code found.
Readiness: N/A
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517 A
Component: ABS/ESP allrad 1726
Coding: 04455
Shop #: WSC 12345
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 B
Component: A4 Klimaautomat 0711
Coding: 00000
Shop #: WSC 63351
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 E
Component: int. Lastmodul RDW 0204
Coding: 00001
Shop #: WSC 63351
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 L
Component: Lenksáulenmodul 0308
Coding: 00042
Shop #: WSC 00000
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 950 F
Component: KOMBI+WEGFAHRS. RB4 D21
Coding: 01400
Shop #: WSC 28049
AUZ6Z0A0119152
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8E0 035 192 T HW: 8E0 035 192 T
Component: RNS-E HIGH EU H76 X---
Revision: 07S Serial number: AUZBZ7J1100110
Coding: 0301111
Shop #: WSC 00000 000 00000
3 Faults Found:
02024 - Perform Adaptation
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 88
Time Indication: 0
Date: 2001.04.23
Time: 01:35:48
00858 - Connection; Radio ZF Output to Antenna Amplifier
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 4
Reset counter: 138
Time Indication: 0
Date: 2001.04.23
Time: 01:36:07
Freeze Frame:
Mileage: 655350 km
Count: 3005
Clock: 16:47
02454 - Microphone Unit (in Front Roof Module) (R164)
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 70
Reset counter: 152
Time Indication: 0
Date: 2001.04.23
Time: 01:35:53
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0504
Coding: 00001
Shop #: WSC 00000
1 Fault Found:
01463 - Alarm triggered by Sensor for anti-theft alarm System
43-00 - Closed
Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
Part No: 8E0 959 433 AJ
Component: Komfortgerát T9F 0619
Coding: 07135
Shop #: WSC 12345
Part No: 8E2959802B
Component: Tõrsteuer.FS BRM 4.11
Part No: 8E2959801B
Component: Tõrsteuer.BF BRM 4.11
5 Faults Found:
01616 - Signal Wire to Interior Monitor
49-10 - No Communications - Intermittent
01561 - Left Rear Door
59-00 - Can't Unlock
60-10 - Won't Safe - Intermittent
61-00 - Won't De-Safe
01562 - Right Rear Door
61-10 - Won't De-Safe - Intermittent
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0301111
3 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 88
Time Indication: 0
Date: 2001.04.23
Time: 01:35:48
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 4
Reset counter: 138
Time Indication: 0
Date: 2001.04.23
Time: 01:36:07
Freeze Frame:
Mileage: 655350 km
Count: 3005
Clock: 16:47
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 70
Reset counter: 152
Time Indication: 0
Date: 2001.04.23
Time: 01:35:53
End ---------------------------------------------------------------------
Any ideas, are there limitations to vcds where a main dealer would be able diagnose
TBH mate vcds & vas5052 both have limitations & the only real difference is VAS can connect, when subscribed, to germany for immo stuff etc, but ref your issue, it would be cheaper for you, than going to a dealer, to get another airbag controller on of ebay that hasnt fired, although a fired one should still work to connect to just to test access only & try swapping it out to see if yours has indeed gone, could be a wiring issue aswell.
Another guy had this other day & me & mate could only advise the same, if he had another controller we could swap over & test, if that didnt work then it would point to wiring mate.
I'm getting a new controler of ebay for myself to upgrade to dual stage, fairly cheap aswell.
ya thought that might be the case thanks for help, any idea of location of module
Yes mate center console hidden under the ashtray/climate area, its bolted to the chassis in that area iirc, so center console out, not a hard job just time consuming.
