Hi, newbie here.
I've just ordered a new S3 which arrives in 3 weeks.
It's already built so I had little say in spec. I've been trying to get a straight answer out of the dealer on 2 simple questions and feel I'm getting the run around re iPhone and iPod connectivity.
The car has factory fitted Concert II (+ Bose) and Bluetooth. All I want to do is add a cradle in the armrest for my iPhone (so it can use the external antennae) and add a dock for an iPod to integrate with the head unit.
I asked the dealer if he could source a car with the factory iPod dock (a £180 option) but we ended up settling on a car without.
Dealer says;
1. He can fit an iPod dock but it would have to be a 3rd party device fitted by a local electrician and quoted £500. He winked and said 'you'd be better off getting it done yourself cheaper'.
2. The Bluetooth will work fine with the iPhone but you can't add the armrest cradle as a dealer fit option so, again, I'd be better off getting an aftermarket cradle on the dash with a charger lead.
Went to local in car electrical specialist (very good local reputation that many main dealers use);
He says;
1. Audi iPod dock is the only one that can integrate with head unit now. Denison (?) used to do one but this doesn't work with latest head units. Glovebox iPod dock is dealer accessory and dealer fit only as there's some software to enable.
2. iPhone doesn't always work with Audi bluetooth, check again with dealer. Armrest cradle is Audi dealer accessory and dealer fit only as software needs enabling. Only iPhone kit he can do would be a Parrot or similar which wouldn't integrate with aerial on car so would need a separate one.
Please can someone tell me a straight answer to my simple and presumably common problem.
Can the dealer retrofit said iPod and iPhone cradles as per factory option?
What should I expect to pay?
Part numbers?
Does the iPhone work properly with latest A3 Bluetooth?How well does the iPod integrate with the Concert II? Track names/playlists/steering wheel controls
Thanks!
Dealer says;
He says;
Part numbers?
Thanks!
