A4 B6 door panel removal - help!
I
imported_Pottsy
Guest
Anyone taken these panels off? Can only find info on the B5....
Started on the passenger door. Screw at bottom, screw under the armrest, wood trim off and 4 revealed screws out. Still as rigid as when all the screws in!
Thanks in advance....
This is for the drivers side:
"pull the bottom, outwards slowly working your way up
You can see how the door panel hooks over the window sill. Once you pull the panel off your gonna need to unhook the cable for the handle release and the wiring plug"
be VERY careful not to break any of the clips
NOTE: The driver side has 7 screws so make sure you havent missed any
/ubbthreads/images/graemlins/beerchug.gif
Thanks! That's all I needed to do. Broke 1 clip on the passenger side and none on the drivers. Didn't seem to matter though.
Sounds miles better with Focal Access's and my Alpine 7878 HU. Sub next!
hope you amped the speakers and dynamatted as will make a big differnce
