I have just the £150 folding mirror option and there is a setting within the vehicle setup in the mmi. I found it strange that it's not enabled by default...
I can't find this option. I wonder if it's different for my 64 plate my15 specI have just the £150 folding mirror option and there is a setting within the vehicle setup in the mmi. I found it strange that it's not enabled by default...
How do I find it? I think I've been done. Looks like a phone call to my dealer next weekIt's not different for MY15, it's in the MMI settings and no, not enabled by default!
How do I find it?
Will do. Lol.Look harder lol.
I'm not near my car but it is in there, I did it on collection.
This is only with the memory mirrors. Unless there is a menu I can't find. I only have the electric folding mirrors.
I followed the steps to set DRL's in the off position, but the option wasn't there - scrolled down through about 100 options but "(9) Tagfahrlicht-Tagfahrlicht nur in Schalterstellung AUTO" was never listed? I was definitely following the instructions correctly, and was able to do other mods successfully. Any ideas?
glospete said: ↑
Im fairly sure this can be changed using VCDS. I done it on my GFs Golf GTD. There was 3 settings as far as I can remember. You are probably on default, so you can go one setting below and one above. So you could go one below meaning the amount of throttle you need to release the car is reduced, which may cure this gripe for you.
- the Hold Assist - the jury's out on this one for me. Of course I can switch it off but I like the idea and it's just that if held on the HA I need to either give a small tap to release it before I pull away or else there is a slight jolt which annoys me.
You are a star! Thank yoiu so much. Where is the best place to buy VCDS - I sent an email to sales@vagcom.biz but no response yet. If I decide not to buy I'll be in contact with you if I may? Is there a definitive list of what can be changed using VCDS? I looked through the thread but it would be easier if there was a complete list as a spreadsheet or suchlike.
Can you turn off the DRL dipping when indicating like on the 8P?
I have looked and looked and so far.... NOPE
I found this on a German site but I have no knowledge if it is correct (poor English is because it is a Google translate job):Can you turn off the DRL dipping when indicating like on the 8P?
We've had this debate before.
It's against the EU directive, and the brightness of the 8V DRL is such that oncoming cars can't see the indicator on the non-combined DRL/Indicstor option.
Why would you increase the risk of an accident ?
