8V VCDS Mods
Silky-S3 Jan 5, 2014
  1. Schizophonic
    Schizophonic Well-Known Member
    931
    471
    It's been mentioned on a number of times. Have another look and do a search fella and you'll find it.
  2. sanrivera
    sanrivera Member
    45
    Um, I think you're thinking about Visual Representation of the Parking Aid:
    . stemei.de VCDS Coding Coding Service Webdesign -.. Stefan Meier - parking sensors activate Visual presentation - VCDS coding, web design
    This is NOT what I'm talking about, as I am not installing sensors. Hence, I'm talking about activation of the rear view camera video display with dynamic help lines:
    https://www.dropbox.com/s/a48719o0ilx5st6/10477722_665735246839391_5471196536796643784_o[1].jpg
    Based on the Kufatec info, some coding is required and I'm wondering if anyone has done this for an A3. Kufatec sells a coding dongle, but if I can do it via VCDS, this is preferable.
  3. Fab_R
    Fab_R Member
    25
    69
    13
    Hi all new to this forum... S3 Sedan on its way.
    Does anybody know if you can turn up the artificial engine sound as per the Golf R Mk7?
    These very much sound like the Audi 5 Cyl Engine.
    I notice the S3 8V is very quiet.
  4. Alerix
    Alerix New Member
    21
    The onboard supply control unit, you have the option the Audi A3 8V to activate the fog lights (NSW) in addition as cornering. With active low bema, the rispettive front fog lamp is thus driven in accordance with steering angle and thus provides additional illumination when turning. How-to Vag Codici per l'attivazione delle luci di svolta
  5. Alerix
    Alerix New Member
    21
    illingworth22 likes this.
  6. Nuggzy
    Nuggzy New Member
    12
  7. snowfree52
    snowfree52 Full LED baby !
    522
    125
    43
    Audi does not use VCDS, they use VAS and this is a completely different system.
    Alerix likes this.
  8. arad85
    arad85 Well-Known Member Team V6 Audi S5 Black Edition
    856
    315
    Alternatively, if the "local garage" does use VCDS, do they have the latest software?
  9. Nuggzy
    Nuggzy New Member
    12
    Now I'm totally confused as I thought the link was for VCDS on the 8v? The menu items were present but they seemed to be in a different order? We just couldn't see the actual line of code to change...
  10. Nuggzy
    Nuggzy New Member
    12
    I'm thinking this might be the case as all the menus were present although they seemed to be labelled slightly differently. Going to try A N Other place today to see if I have better luck.
    SW14NY'S likes this.
  11. snowfree52
    522
    125
    43
    I meant audi dealers
  12. arad85
    856
    315
    I thought you did. But "local garage" is ambiguous.... Could be Audi, could be an independent.
  13. Nuggzy
    Nuggzy New Member
    12
    Sorry guys I meant local garage not the dealer.
    Quick question: My car is an s-line but do I need an upgraded light package for the rear DRL mod? I don't have this so am wondering if that was also part of the issue...
  14. arad85
    856
    315
    No. I have the standard s-line and have rear DRL activated.
    Nuggzy and illingworth22 like this.
  15. Alan Porter
    Alan Porter New Member
    I have VCDS and am about an hour from Nottingham....
    Nuggzy likes this.
  16. Nuggzy
    Nuggzy New Member
    12
    PM Sent
  17. illingworth22
    illingworth22 Active Member TeamMisano Audi S3 Audi A3
    476
    152
    43
    Exactly how.. If you don't mind me asking?
  18. Nuggzy
    Nuggzy New Member
    12
    Do you have instructions including the version of VCDS mate?
    Thanks in advance
  19. arad85
    856
    315
    illingworth22 and Nuggzy like this.
  20. arad85
    856
    315
    Latest version of VCDS.
    Nuggzy likes this.
  21. camoto
    camoto New Member
    22
    Does anyone know if it is possible to show the current gear number in the DIS when in "D" or "S" like you could do with the B8?
    example: so instead of just "D" it would display "D1" for 1st gear.
  22. monopole
    monopole Well-Known Member
    1,154
    470
    MY15 S3 Full Scan, if it helps anyone
    car has the following options/specs:
    Convenience pack / parking plus
    Advance key
    Folding mirrors
    Tech pack (not connect)
    B&O
    **Autolock when leaving/away from the car enabled** http://www.audi-sport.net/vb/new-a3-s3-8v-chassis/224353-automatic-lock-8v-a3-vcds-mod.html
    Friday,08,August,2014,15:35:22:58778
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 14.7.2.0 (x64)
    Data version: 20140714
    VIN: WAUZZZ8V1FAXXXXXX License Plate: 1ST_SCAN
    Mileage: 244km-151mi Repair Order:
    Chassis Type: 8V (5Q0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 2B 42 44 52 55 5F A9
    VIN: WAUZZZ8V1FAXXXXXX Mileage: 244km-151miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    2B-Steer. Col. Lock -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    5F-Information Electr. -- Status: OK 0000
    A9-Struct. Borne Sound -- Status: OK 0000
    Address 01: Engine (J623-CJXC) Labels: 06K-907-425-V1.clb
    Part No SW: 8V0 906 259 A HW: 06K 907 425 B
    Component: 2.0l R4 TFSI H13 0002
    Revision: --H13---
    Coding: 0A1D00322426010B3004
    Shop #: WSC 06314 790 00021
    ASAM Dataset: EV_ECM20TFS0208V0906259A 001004
    ROD: N/A
    VCID: 3E7503A3A1922FCAB1-806B
    No ASAM data for: "EV_ECM20TFS0208V0906259A" (AU37)
    No fault code found.
    Readiness: 1110 0001
    Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb
    Part No SW: 0D9 300 012 L HW: 02E 927 770 AQ
    Component: DQ250-6A MQB H52 4517
    Revision: 03252204 Serial number: TFK01406100419
    Coding: 0014
    Shop #: WSC 04742 780 00200
    ASAM Dataset: EV_TCMDQ250021 001001
    ROD: EV_TCMDQ250021_AU37.rod
    VCID: 1F4BDE27065846C29A-804A
    Address 03: ABS Brakes (J104) Labels: 5Q0-907-379.clb
    Part No SW: 5Q0 907 379 L HW: 5Q0 907 379 G
    Component: ESC H31 0471
    Revision: 00000000 Serial number: 61804000001935
    Coding: 32F193A254222A710180070541CB694CC92A5480E08296F6024100788608
    ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
    ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
    VCID: 45876C4FC4447C12F0-8010
    Address 05: Acc/Start Auth. (J518) Labels: None
    Part No SW: 5Q0 959 435 A HW: 5Q0 959 435
    Component: VWKESSYMQB 021 0604
    Revision: 00021000 Serial number: 0338548241
    Coding: 030C0C
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_KessyHellaMQBAB 002011
    ROD: EV_KessyHellaMQBAB_AU37.rod
    VCID: 3A7D0FB3BDBA03EA8D-806F
    Address 08: Auto HVAC (E87) Labels: 8V0-820-043.clb
    Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
    Component: AC Automat H13 0052
    Revision: 20026000 Serial number: 00000000361979
    Coding: 03100004000000011000000000001100
    ASAM Dataset: EV_AirCondiFrontVaAU37X 008020
    ROD: EV_AirCondiFrontVaAU37X.rod
    VCID: 336322979AD0F2A24E-8066
    Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
    Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AJ
    Component: BCM MQBAB H H18 0134
    Serial number: 01011418201317
    Coding: 07051A46C24122F503844004B31C07A80800000000000000000000000000
    ASAM Dataset: EV_BCMCONTI 013000
    ROD: EV_BCMBOSCH_AU37.rod
    VCID: 0009BD5B9BE6993A83-8055
    Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119
    Component: WWS370 140620 041 0580
    Serial number: 140625212252
    Coding: 0A47F7
    Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B
    Component: G397_RLFS H06 0002
    Serial number: 22825732
    Coding: 00006C
    Subsystem 3 - Part No SW: 8V0 941 531 K HW: 8V0 941 531 K
    Component: E1 - LDS MQB H05 0032
    Serial number: 15 04 2014 00001771
    Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
    Component: Sensor, DWA 005 0315
    Serial number: 000000000ZY141554PSC
    Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
    Component: Sirene, DWA 004 0311
    Serial number: 00000000000059971641
    Address 10: Park/Steer Assist (J791) Labels: 5Q0-919-294.clb
    Part No SW: 5Q0 919 294 J HW: 5Q0 919 294 A
    Component: PARKHILFE 8K H03 0051
    Revision: -------- Serial number: 39331418105438
    Coding: 0030050011
    ASAM Dataset: EV_EPHVA18AU3700000 002024
    ROD: EV_EPHVA18AU3700000_AU37.rod
    VCID: 428D7753D56A4B2AD5-8017
    Address 15: Airbags (J234) Labels: 5Q0-959-655.clb
    Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
    Component: AirbagVW20 011 0361
    Serial number: 003M2R07C8FA
    Coding: 98CCC0000C0000005C5400CA00C800000065
    ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
    ROD: EV_AirbaVW20SMEVW37X_AU37.rod
    VCID: 4B935A77E2208A6226-801E
    Crash sensor for side airbag; driver side:
    Subsystem 1 - Part No SW: ----------- HW: 480 000 107 14
    Component: SideSensor_Df 001 0887
    Serial number: 3576700000072C78301P
    Coding: 2D2D2D
    Crash sensor for side airbag; passenger side:
    Subsystem 2 - Part No SW: ----------- HW: 480 000 107 14
    Component: SideSensor_Pf 001 0887
    Serial number: 358670000003E638301O
    Coding: 2D2D2D
    Crash sensor for side airbag; rear driver side:
    Subsystem 3 - Part No SW: ----------- HW: 480 402 306 14
    Component: SideSensor_Dr 001 6149
    Serial number: 3516502C11617D20329-
    Coding: 2D2D2D
    Crash sensor for side airbag; rear passenger side:
    Subsystem 4 - Part No SW: ----------- HW: 480 402 306 14
    Component: SideSensor_Pr 001 6149
    Serial number: 3526502C11617D21827+
    Coding: 2D2D2D
    Crash sensor for front airbag; driver side:
    Subsystem 5 - Part No SW: ----------- HW: 480 401 505 14
    Component: FrontSensor_D 001 6149
    Serial number: 3556502BB157E9E3B04U
    Coding: 2D2D2D
    Pedestrian protection crash sensor; driver side:
    Subsystem 6 - Part No SW: ----------- HW: 480 401 006 14
    Component: PedP_Sensor_D 001 6149
    Serial number: 2286502C5156EA0580FK
    Coding: 2D2D2D
    Pedestrian protection crash sensor; passenger side:
    Subsystem 7 - Part No SW: ----------- HW: 480 401 006 14
    Component: PedP_Sensor_P 001 6149
    Serial number: 2296502C5156EA052358
    Coding: 2D2D2D
    Center pedestrian protection crash sensor:
    Subsystem 8 - Part No SW: ----------- HW: 480 401 006 14
    Component: PedP_Sensor_C 001 6149
    Serial number: 2306502B3156E9E4F28O
    Coding: 2D2D2D
    Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
    Part No SW: 8V0 953 521 CH HW: 5Q0 953 549 C
    Component: Lenks. Modul 002 0110
    Revision: -------- Serial number: 01071408490365
    Coding: A418
    ASAM Dataset: EV_SMLSKLOMQB 017001
    ROD: EV_SMLSKLOMQB_AU37.rod
    VCID: 020DB75395EA8B2A95-8057
    Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.clb
    Part No SW: 8V0 920 971 J HW: 8V0 920 971 J
    Component: KOMBI H02 4291
    Coding: 27AD081A2B8026000101E8001000000000000000
    ASAM Dataset: EV_DashBoardVDDMQBAB 009040
    ROD: EV_DashBoardVDDMQBAB_AU37.rod
    VCID: 4481714BCF7E451AE7-8011
    Address 19: CAN Gateway (J533) Labels: None
    Part No SW: 5Q0 907 530 T HW: 5Q0 907 530 F
    Component: GW MQB High 128 1188
    Revision: -------- Serial number: 0002128316
    Coding: 030100042F085A005B0002681C0B00000001010000000000000000000000
    ASAM Dataset: EV_GatewLear 011016
    ROD: EV_GatewLear_AU37.rod
    Alternator:
    Multifunction unit control module:
    Subsystem 2 - Part No SW: 8U0 951 528 C HW: 8U0 951 528 C
    Component: E221 - MFL H02 0014
    Serial number: 19 06 2014 C0054990
    Battery Monitoring Control Module:
    Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
    Component: J367-BDMHella H03 8043
    Serial number: 7349603603
    Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
    Part No SW: 5Q0 905 861 A HW: 5Q0 905 861 A
    Component: ELV-MQBA H01 0120
    Revision: 00000000 Serial number: 14000162177002
    Coding: 5D00000000000000
    ASAM Dataset: EV_ELVMarquMQB 004111
    ROD: EV_ELVMarquMQB.rod
    VCID: 3461218B9FDEF59A57-8061
    Address 42: Door Elect, Driver (J386) Labels: 5QX-959-X93-42.clb
    Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
    Component: TSG FS 020 0025
    Serial number: 20061401100784
    Coding: 00519E205C01040000001002
    ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
    ROD: EV_DCUDriveSideEWMAXKLO.rod
    VCID: 40897D5BDB66593AC3-8015
    Address 44: Steering Assist (J500) Labels: 5Q0-909-144.clb
    Part No SW: 3Q0 909 144 F HW: 3Q0 909 144 F
    Component: EPS_MQB_ZFLS 503 5043
    Coding: 8103
    ASAM Dataset: EV_SteerAssisMQB 010031
    ROD: EV_SteerAssisMQB.rod
    VCID: 35671C8F94A4EC9260-8060
    Address 52: Door Elect, Pass. (J387) Labels: 5QX-959-X92-52.clb
    Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
    Component: TSG BFS 020 0025
    Serial number: 21061403111039
    Coding: 005196205E01040000001002
    ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
    ROD: EV_DCUPasseSideEWMAXKLO.rod
    VCID: 3F8B7EA7A69826C2BA-806A
    Address 55: Headlight Range (J431) Labels: 5Q0-907-357.clb
    Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
    Component: LWR-ECU 005 0080
    Revision: -------- Serial number: --------------
    Coding: 01AE000001000000
    ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
    ROD: EV_HeadlRegulVWLWRMQB.rod
    VCID: 75E7DC8FD424AC92A0-8020
    Address 5F: Information Electr. (J794) Labels: None
    Part No SW: 8V0 035 020 D HW: 8V0 035 020 D
    Component: MU-H-ND-EU H43 0356
    Serial number: A305F0EB003620
    Coding: 017303010000000021111102000A00002F00022701000100DE
    ASAM Dataset: EV_MUHig6C3HBAS 001040
    ROD: EV_MUHig6C3HBAS_AU37.rod
    VCID: 2C5139EB47EEAD5A0F-8079
    Engine Control Module 2:
    Subsystem 1 - Part No SW: V03 959 800 PS HW: -----------
    Component: ECE 2014/2015 --- 0086
    Serial number: --------------------
    Seat Adjustment Driver Side:
    Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
    Component: DU High H49 0013
    Serial number: AUZ8Z9EY2018SK
    Sound System:
    Subsystem 3 - Part No SW: 8V0 919 614 L HW: 8V0 919 614 L
    Component: ControlUnit_H H81 0816
    Serial number: C1000014041400030281
    Door Electronics Rear Left:
    Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
    Component: Gracenote --- 1010
    Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
    Part No SW: 8V0 907 159 HW: 4H0 907 159 A
    Component: SAS-GEN 2 H06 0012
    Serial number: 140620201036
    ASAM Dataset: EV_SoundActuaGen2AU64X 003010
    ROD: EV_SoundActuaGen2AU64X.rod
    VCID: 7DF7C4AFEC14F4D2E8-8028
    End-------------------------(Elapsed Time: 04:02)--------------------------
  23. monopole
    1,154
    470
    it does it this way already!!!!
  24. camoto
    camoto New Member
    22
    Not on my US Spec A3. That must mean there is a way to toggle it.
  25. Alerix
    Alerix New Member
    21
  26. monopole
    1,154
    470
    is that not configurable thru the MMI?
  27. Alerix
    Alerix New Member
    21
    this was not on my A3 is not configurabile thru the MMI, this of series of many A3 8V/8VA
  28. jaguar1187
    jaguar1187 Member
    47
    32
    Does anyone know if there is a way to removal the numbers from and display of the volume. I know it's a little OCD but I have to have it on set values otherwise it winds me up. This didn't happen on the 8P and I loved it for it.
  29. sstorra
    sstorra New Member
    29
    9
    Using some Google-Fu, I believe I have found some module security codes, including some people have been looking for :
    [03] ABS Brakes : 20103 (Various references)
    [13] Auto distance regulation : 14117 (https://vcp-forum.de/viewtopic.php?f=6&t=303)
    [44] Steering Assist : 19249 (https://vcp-forum.de/viewtopic.php?f=6&t=358)
    [A5] Frt Sens. Drv. Assist : 20103 (http://www.golf7gti.com/topic.php?p=50973#real50973)
    I am personally particularly interested in module 13, for the ACC default distance setting in MMI mod :
    [13] Auto distance regulation, Adaptation, Channel 7, change 0 to 1, Save. Reboot MMI.
    My car is still on a ship, so I can't test them - yet - I hope they work and hope they help others out!
    arad85 and Schizophonic like this.
  30. pauly69
    pauly69 Well-Known Member
    303
    275
    LOL I do that too; you are not alone :)
    slinemfc and jaguar1187 like this.
  31. arad85
    856
    315
    Confirmed working here - many thanks :)
  32. arad85
    856
    315
    Also, anyone know of any good mods that the codes above can now enable you to do?
  33. papaspeter
    papaspeter New Member
    10
    Hi I am interesteded in too!
    If you find any infos pls send me these also.
    I have a camera but it doesn't appear to display. I found the pins in the plug
  34. rajeevx5
    rajeevx5 S3 VCDS Map User Team Sepang Audi S3
    170
    50
    Does anyone have the ABS unlock code as 20103 and 40168 don't seem to work?
  35. cemerson
    cemerson Well-Known Member Team Cosmos quattro Audi A3 S-line owners group TDi DSG
    4,597
    1,184
    I got this done by my dealer for free. You could always ask them to do it as part of the PDI? Plenty of people here have done the same since I got mine done without an issue.
  36. cemerson
    4,597
    1,184
    Steering assist could potentially be a very useful module though, if it can stop the lane assist turning off all the time on straight bits of road!
  37. sstorra
    sstorra New Member
    29
    9
    Yes, I was aware various people on here did that, and despite preferring to be able to do it myself if possible, I had asked the dealer to do it at PDI, however that's no longer necessary, as per arad85's reply I'll be doing it myself :
  38. Woody86
    Woody86 Active Member
    201
    76
    Does anyone know if the electric folding mirrors (non memory) and be enabled to fold and unfold on locking and unlocking?
  39. cemerson
    4,597
    1,184
    Yes, it's a setting in the MMI.
    Well, it folds on lock and unfolds on ignition on - better that way IMO. If it did it on unlock it'd just be whirring away every time you went to get something from the car without driving it!
  40. Woody86
    201
    76
    This is only with the memory mirrors. Unless there is a menu I can't find. I only have the electric folding mirrors.
