2015 or 2016 car?
VCDS Version? if v15.x update to the current Beta v16.x as it has better support for UDS and our cars.
To double check are these the adaptations you changed?
- (2) - Acknowledgement Signals - Akustische Rueckmeldung Verriegeln = Active
- (1) - Acknowledgement Signals - Akustische Rueckmeldung entriegen = Active
- (7) - Menuesteuerung akustische Rueckmeldung = Active
If yes then I would:
- Ignition in position 1
- Make sure the MMI is not in CAR mode
- Un-code (7) to remove the menu configuration via VCDS
- Three finger reset the MMI
- Once MMI is back up turn off ignition and remove the key for 5 mins
- Doors closed but not locked and windows closed
- Make sure the MMI is not in CAR Mode
- Recode the menu via VCDS
- Once MMI is back up check to see if the menu has popped
- Activate Tone When Locking Option via MMI Menu
- Shut down VCDS, exit car and test
I know people have reported issues with 2015 cars not working but I have not experienced this myself and this is the process I follow. Not had any reports of issues with 2016 cars as yet and not worked on any so far. Let us know how you get on...
