Well, i've just had my friend from VW fit and code my new stalks so the full DIS will work and we were a bit unsure of which adjustments to make on the vagcom.
We went for the 0=DIS setting as shown on vagcom and not the 1=DIS with menu or the 2= DIS with menu and adjustments or something like that??
All seems to work fine now though i do have a high level brake light out warning??, surely this should've shown befor the upgrade?? easy fix??
Also, i have the expected low washer fluid warning, does anyone know if the loom for this is part of the standard engine loom?? and if so, is it just a case of buying a sender and fitting it??, or would i need to buy a new washer bottle?, is it a different bottle that allows fitment of the sensor?. ( just asking before i start pulling things to pieces)
I've been done a search of the DIS related topics and none are clear on this, would be nice if someone who's been in my position could give some guidance.
mak
mak
