chorus power up
silvercityfox
when the unit is installed it goes into safe mode ok, but when the code is put in, it goes to radio for a couple of seconds then powers off completely, any ideas ?
Are you installing this as a retrofit into a different car?
You may find the Chorus is CANBUS controlled and your car isn't or vice-versa, this will give you a power up issue and you'll need to turn the HU on/off manually and it will turn itself off after 60mins.
Does it do the same thing with the ignition on?
Can you turn it on manually after entering the code?
Took the chorus out my TT to fit a diff HU but didn't like it so put the chorus back in, same wiring etc, but just powers off completely after a couple of secs after code is inputted.
961
704
smo
772
