Audi_Alex
Hey guys,
i've just noticed that my headlight washers have stopped working which i suspect is due to using lower grade washer fluid from halfords which has blocked up the pipes. This has stopped the pump from working, and subsequently blown the fuse!
could anyone tell me if the circuit for this pump is linked with the rear washer, as this doesn't work any more??
i guess i need to clear the pipes out somehow, so should some warm/hot water do it? Or would i need to disconnect the pipe and force some pressure down it?
Can't seem to find the answer to this in the search, so when I solve it, i'll post the result here
Cheers in advance!
Alex
Cheers in advance!
Alex
