- Joined
- Jul 15, 2009
- Messages
- 8,263
- Reaction score
- 688
- Points
- 113
- Location
- London
- Website
- www.aythreee.com
Just had the cambelt and waterpump changed on my 2.0 FSi. I have now noticed a single knock when I do the following:
1) if I pull off in first gear reasonably quickly as soon as I am totally off the clutch with a bit of gas I hear a knock
2) changing up to second as soon as I am totally off the clutch with gas I hear a knock
3) reverse reasonably quickly, again when totally off the clutch I hear it.
4) if I drive along in first gear with the clutch fully up and then come off the gas totally so i can feel the car slow/lurch (still with the clutch up) I hear the knock. Knock happens again if I press the gas again, still with clutch up.
The knock sounds like it is coming from inside the car, drivers side. But can't be 100% sure that it is. It's not a very loud knock, can only really hear it with windows closed.
Thought it could be caused by something moving about that I keep in my car, but the knock doesn't happen when breaking hard or when going over bumps. Also doesn't happen if I rev car in neutral, or in gear with clutch down.
I plan to take car back to dealers, but grateful if anyone has any ideas of what it might be.
Seems like it's linked to the accelerator/gearbox??, because as above, can also hear it when first gear is fully engaged and I go on/off the gas.
I'm no good with engines..... does the cambelt/waterpump have anything to do with accelerator/engine speed, or is there anyway possible that it could cause a knock???
Cheers guys.
Cheers guys.
