revo stage 2 remap mods 2 do before
bansheeboyo
aberdeenshire
righty oh lads im about to book a revo stage 2 remap i have a ko4 turbo from back draft that fits on 2 k03 manifold ,way 2 fit forge fmic soon buyin forge splitter dv and dv relocation kit, milltek exhaust system
any other mods you can think of that i sould do before remap
injectors or what not
cheers scott
Might wanna look at a 4bar FPR, panel filter, if your running the k04 you might need a 3" maf too... Downpipe is defo worth doing too.
i was led to beleive the KO3 setup was very restrictive... ie the manifold and downpipe... would you not have been better going for a true KO4 setup first ???
For a Revo stage 2 you need to have....
An uprated DV.
An uprated intake (Panel or induction).
A turboback exhaust - This is the main change in stage 1 to stage 2.
And a 4 bar fuel regulator.
An FMIC will make a big differance in the hot weather coming up if running a map and bigger turbo....
Also save your self some money and buy the Forge 007P DV as the Split-R is as much use as a chocolate teapot :)
Hope this helps.... :)
so would i see any gains in putting in diffrent injectors
Assuming you have an A3 and you still have the A3/K03 injectors then I would have thought you would need at least the S3 ones and an S3 fuel pump.
Not sure of the pump fitment as I believe they differ on quattros unless yours is in which case you may be ok.
846
35
679
