Forge upgrade model number ?
flippy
Trying to do some purchase from Forge to my S3 S3 2001. Couple question hope someone can clairfy
- there are 2 model of DV from forge website. FMCL007P and FMCL007P. Can someone tell which is better and the different?
- FMDVSPLTR - The Splitter, a Recirculation and Blow Off Valve ... I really interested any effect of performance dropping and how its blow off sounds act.
The Forge valve 007P is great on your 1.8T
http://www.forgemotorsport.co.uk/content.asp?inc=product&cat=1703&product=FMCL007P
This type of valve is a single piston , single spring diverter valve, it is
silent in operation
It locates in the same position as your original black plastic Bosch valve ,
It will not give you any issues or check engine lights .
The Forge 007P valves are a two piece valve which are serve and guaranteed for
or the Split R
http://www.forgemotorsport.co.uk/content.asp?inc=product&cat=1703DV&product=FMDVSPLTR
The Split R valve design will automatically keep the MAF and ECU happy with regards to fault codes. It has a restricted Atmospheric port to the correct percentage for this reason.
The choice is yours they both work well . and are avialable from the vendors on the forum
S
769
439
