dump valve hassle
torkie1
s3 u no
hi recently got a recirc dumpvalve n i replaced the standerd 1 with my new 1 but after a few minuets the pressure from the turbo pushes it out the pipe even wen i have tightend the jublie clip as tight as it will go.it is in the same way as the standerd 1 ne help will b apreciated.
thanks
New one? What one would that be the standard one or an aftermarket one?
G
the after market 1 jus bursts off the pipe comin from the turbo
Check for Oil inside the pipe where the Valve inserts into. If you have oil on there not only will it be easier to burst off, but it could also be an indicator to another problem.
817
581
35
3K
14
21
