I just finished installing the entire kit from Robin on my 2012 A3 Sportback 4 door (US version). I also installed the entire LED kit from Trups. Everything went well, and spent about 4-5 hours doing it all - nice packages together. So here is an exhaustive list of everything installed all at the same time:
Footwell lights front and rear
Puddle/warning lights all four doors
LED lights for the following:
- Overhead front and map lights
- Vanity mirror lights
- Overhead rear map lights
- Glove box
- Trunk (boot across the pond)
- Rear license plate
- Puddle/warning in 4 doors
- Footwell front and rear
Notes for others:
- When cutting the holes under the door cards for the puddle lamps, you can use a heavy duty box cutter and just push in steadily to get nice clean cuts. I created a cardboard template for the correct size hole from where the red warning lenses were installed in the doors since they are the same size. Outlined it in black felt pen, then carefully cut the holes to the exact size and each light snapped into place as intended. They can be pulled back out just as easily if needed.
- For my car, on the puddle/warning lights, I used pins 18 for power and 19 for ground (earth) on the front doors and pin 1 for power and pin 2 for ground in the rear doors. On all 4 doors I has to tap into the ground wire in the existing connector and solder then together. I know some people have been able to just push the pins into empty slots. So it could be my US model or maybe 2012 models, I don't know, but there is a little bit of cutting and soldering.
- The LED lights from Trups need to be adjusted carefully to stay in place. They plug into the lights where a bare bulb with contacts used to be. So you need to carefully bend the leads around a but so that when you plug in his little white socket into the leads, it stays in place and does not pop out easily. Not a big deal, but I didn't do that initially and about 75% of my lights were not working. Just adjusted them all and everything is good.
- Removing the front door cards was pretty obvious - remove a few screws and pop off the card. The rear doors were not as obvious. There is one screw behind the tweeter enclosure - similar location to the front door, but there is also a screw behind the panel where the window up/down switch is located. So pop up the cover over the window switch first and you will see it.
Here are the two settings I had to change for the footwell lamps:
Since this is a 4 door, there are 4 places to change for the puddle/warning lamps - in all cases I added 64 to the value that was already in place. Under Chassis, I made the change in the following 4 places:
42 - Door Elect, Driver
52 - Door Elect, Pass.
62 - Door, Rear Left
72 - Door, Rear Right
The below picture was taken in my garage in complete darkness with no other lights on. The whole interior is lit up, along with the ground around the bottom of the doors.
