cv joint noise - difficult to change yourself?
mordz
Audi S3 (2000)
Ok so the boot came of a few weeks back, it was a good 3 weeks till i could get the car in to the garrage, so i used some hefty tie wraps to put the boot back on.
car in for service and had the boot fitted propperly, the guy told me if it still makes a noise then i need a new joint. if anything the noise is getting worse and its another 3 weeks before the have a slot to change it for me.
How hard is it to do the work yourself? im a novice mechanic but can get some help from a mate too. should i attempt it?
what parts will i need? is there a cv kit i need, also i have seen the inner and outer CV listed. which do i need im guessing outer is the wheel and inner being the engine side?
thanks for help dudes.
they are not too hard to change, a new boot kit from audi is 18 quid with boot , clips , grease and new stretch bolt. Dont know how much a cv joint is but let me know as I also need one as I have a slight knock on full lock on my drivers side.
You need the right tool to clamp the clips up (nb i didn`t for the first boot I changed and the clip came off hence the damage to the cv joint :( )
the tool is 10 - 20 quid depending on manufacturer.
try audi for parts then GSF, auid are sometime surprisingly cheap.
The kit isnt really what you need - if you try GSF they'll price you a new driveshaft - it'll come with the boot already on etc, just a case of pulling the old one out and putting the new one in.
If you're careful then it shouldn tbe too hard a job
thanks for the tips dudes,
i checked GSF the do the inner or outer for around £40 quid. tube of cv grease is a few quid
i just called a local (none audi garage/specialist garage) and they said they would do it for £80. might be easyer. if the tool is £20 quid also.
i wouldnt mind doing it myself so i know how. woudlnt be too bad if weather was ok.
what do you guys recon?
£80 sounds not bad at all, as long as they're actually replacing the joint - i'm surprised its that cheap as with alot of cars you need a whole new driveshaft when the CV joint has gone, which i'd expect to be about £80 itself.
maybe they are guestimating its just the joint. ill let you know by end of play tomoz.
The audi driveshafts are very easy to change as are the cv joints too.not worth paying them £80 in my opinion
970
12
