Marking on fuel consumption meter
JSR913
North Yorkshire
What does this little upside triangle denote, it moves from the left hand side on start up and then hovers around the middle while travelling Anyone know ?
1715120500901
It points to where on the scale below the average journey consumption (the number above) is. In your picture 47.4 is higher than 40 so the marker is slightly tot he right of the 40. If the actual instantaneous consumption is to the left of the marker you are using more fuel than the current average, to the right you are using less fuel than the current average.
Reactions: NHN
when you brake your actually charging battery apparently!
That is the MHEV component of the car. Decelerating in gear causes one level of regeneration, breaking adds an additional level
Thank you, but im not convinced, given the scale of the instantaneous consumption, 47.4 would be much farther to the right, indeed last night at 55.9 mpg average the marker was in about the same place.
I have noticed too that during driving it does move up and down, though not much but discernible but have yet to associate that movement with a specific vehicle behaviour
The arrow definitely moves as the average consumption changes
IMG 3275
IMG 3276
Yes it does but I don’t see it move proportionally to the average consumption. I have seen averages of 55+ but the arrow only at a fraction to the right of the 40 mark
The scale above 40 is not linear and changes to whatever it decides is appropriate
3K
12
3K
934
10
5K
