Morning folks… I’m looking for any insight in to this issue i have with the car… I’ll try and best describe it…. But boost hesitation would be the best description for it. So when im cruising about 1800rpm, and say in forth or fifth (doesn’t actually matter what gear I’m in, but definitely the rev range around the 1800 mark) and i press the accelerator theres a definite delay whilst it feels like boost pressure is building and then sort of goes ‘there you go, there’s your boost’ and off the car goes and accelerates on boost as normal. It almost feels as if the car decelerates initially, like theres no power at all. I often box down in to a lower gear (in to higher rpm band) to drive round the problem. The car wasn’t like this when i first got it about a year ago now And I’d say the problem is getting slowly worse. I cleaned out the egr and intake about 5 months ago as they were pretty coked up.
What do we think the issue it here? I’ll scan it for codes this morning using vcds see if that throws any light.
