Tuesday,12,March,2024,18:53:54:46083
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 23.11.0.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20231027 DS351.0
www.Ross-Tech.com
VIN: WAUZZZ8P69A008255 License Plate:
Mileage: 154700km-96126mi Repair Order:
Chassis Type: 8P-AU35 (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WAUZZZ8P69A008255 Mileage: 154700km-96126miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (BSE) Labels: 06A-906-033-BGU.lbl
Part No SW: 06A 906 033 JL HW: 06A 906 033 JL
Component: BSE S71 1.6 2V 2791
Revision: --H01--- Serial number: AUX7Z0H5FNN0EH
Coding: 0044071
Shop #: WSC 06314 000 00000
VCID: 72BDCBAB48A461AA297-8026
VINID: 9D196AAAA2201894400080851484524D24
1 Fault Found:
18359 - Radiator Fan 2 (V177)
P1951 - 007 - Movement Restricted / Jammed
Freeze Frame:
RPM: 640 /min
Mass Air / Rev.: 92.7 mg/str
Temperature: 102.0°C
Voltage: 13.67 V
Readiness: 0010 1101
Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 CC HW: 1K0 907 379 CC
Component: ESP MK60EC1 H46 0175
Revision: 00H46001
Coding: 0000000000000000000000000000000000000000
Shop #: WSC 00020 790 00000
VCID: 75B7F0B735CA76920C5-8020
5 Faults Found:
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 36
Time Indication: 0
Date: 2024.03.09
Time: 05:08:57
Freeze Frame:
Count: 3
Count: 0
Count: 20992
Count: 195
Count: 48896
Count: 65280
Count: 0
Count: 0
01279 - Longitudinal Acceleration Sensor (G251)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 36
Mileage: 154700 km
Time Indication: 0
Date: 2024.03.09
Time: 05:08:17
Freeze Frame:
Count: 3
Count: 2
Count: 12800
Count: 212
Count: 48128
Count: 65280
Count: 512
Count: 0
01435 - Brake Pressure Sensor 1 (G201)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 36
Mileage: 154700 km
Time Indication: 0
Date: 2024.03.09
Time: 05:08:17
Freeze Frame:
Count: 3
Count: 2
Count: 12800
Count: 279
Count: 48128
Count: 65280
Count: 512
Count: 0
00778 - Steering Angle Sensor (G85)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 36
Mileage: 154700 km
Time Indication: 0
Date: 2024.03.09
Time: 05:08:17
Freeze Frame:
Count: 3
Count: 2
Count: 12800
Count: 295
Count: 48128
Count: 65280
Count: 512
Count: 0
01423 - Lateral Acceleration Sensor (G200)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 36
Mileage: 154700 km
Time Indication: 0
Date: 2024.03.09
Time: 05:08:17
Freeze Frame:
Count: 3
Count: 2
Count: 12800
Count: 270
Count: 48128
Count: 65280
Count: 512
Count: 0
Address 08: Auto HVAC Labels: 8P0-820-047.clb
Part No: 8P0 820 047 B
Component: J255 Klima Man H07 0030
Shop #: WSC 00000 000 00000
VCID: 2F3B02DF9B160C42869-807A
No fault code found.
Address 09: Cent. Elect. Labels:. 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000008586499
Coding: 10AC2F81B0141380EF00001C0000000000084A1564010401002800000000
Shop #: WSC 06314 000 08192
VCID: 48C949431EB8BB7AA73-801C
Subsystem 1 - Part No: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00056595
Shop #: WSC 06314
1 Fault Found:
01519 - Bulb for Back-Up Lights; Right (M17)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 75
Mileage: 154666 km
Time Indication: 0
Date: 2024.03.03
Time: 23:39:00
Freeze Frame:
ON
Voltage: 11.80 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags (J234) Labels:* 8P0-959-655-10.clb
Part No SW: 8P0 959 655 J HW: 8P0 959 655 J
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003000000000 Dataset Number: 8P0909602H 0012
Coding: 303142383038303030374A55305238503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4_AU35.rod
VCID: 49CF4C4709324272B8D-801C
Crash sensor for side airbag: driver side:
Serial number: 3572DRB40000762D0B4T
Front Passenger's Side Airbag Crash Sensor:
Serial number: 3582DRB400007654A0CV
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 35128RB400003CCBA2F/
Passenger side rear thorax airbag crash sensor:
Serial number: 35228RB400003D14EAEZ
Crash sensor for front airbag: driver side:
Serial number: 35547RB40000283CABA-
Crash sensor for front airbag: front passenger side:
Serial number: 35647RB400003CB2799Y
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
Component: J0527 036 0070
Coding: 0000002
VCID: 78A9F9832ED80BFA173-802C
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 951 S HW: 8P0 920 951 S
Component: KOMBIINSTR. VDO H07 0820
Revision: D0H07004 Serial number: 1245H004000242
Coding: 0004428
Shop #: WSC 12345 123 12345
VCID: 45D7407729AAA6125C5-8010
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K08607035D
Coding: E9807F060002022103
VCID: 353730B7794A3692CC5-8060
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H07004 Serial number: AUX7Z0H5FNN0EH
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
Component: Tuer-SG H03 0060
Coding: 0000692
VCID: 43D35E6F279E9822721-8016
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.078 H08 1901
Shop #: WSC 02069 000 90108
VCID: 363537BB644C3D8AC5F-8062
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 J
Component: KSG H11 0080
Coding: 1980202002186D0985054C9FC637
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
