31satara
Hi all, a new member hoping for some help with an issue I'm struggling with. The car is a 2009 A3 cabrolet. I few weeks ago over a couple of days there was some intermittent passenger side electrical issues and alarm triggers. It soon settled to a point where nothing electrical is working on the near side door (mirror, lights, central locking, window), nor the near side rear window. The alarm will set even though the passenger door remains unlocked, but doesn't trigger if the door is opened. Initially I thought it might be the drivers door wiring harness as I had repaired wires here in the past (and there was evidence of a previous repair). So this time I replaced the whole plug and checked all wires for continuity between plug and other end of the harness before reconnecting. However, this made no difference - exactly the same issues. I had also checked fuses. I have now checked the continuity of the wires in the passenger door harness and all were good. There was a very small amount of corrosion on a few pins into the control module which I carefully cleaned all up but this made no difference - exactly the same issues. There was a live 12V supply to this module. I then checked the near side rear window module. All clean and dry, and a live 12V supply. I've rechecked all the wires in the drivers door harness and the plug and socket again - all seem fine. I'll copy a shortened vcds scan with just the faults below. Has anyone got any ideas what to do next? Do I start replacing modules? I know all the modules are linked, and that the drivers can affect all the others - or could it be the passenger one affecting the rear as well? It seems unlikely that both would fail together. Or is there something else, maybe another modue or other wiring I should be looking at and checking? Or maybe a different way of checking wiring or modules? Any advice appreciated, thanks.
Chassis Type: 8P (1K0)
VIN: TRUZZZ8P391007895 Mileage: 146060km-90757miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
26-Auto Roof -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 1010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: Cannot be reached 1100
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: Malfunction 1010
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BD HW: 8P0 820 043 BD
Component: KlimavollautomatH03 0080
Revision: 159745 Serial number: 8P0820043BD
Shop #: WSC 00000 000 00000
VCID: 6FED66BB7E9D05EB22-803A
1 Fault Found:
01332 - Door Control Module; Passenger Side (J387)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 21
Reset counter: 159
Mileage: 145677 km
Time Indication: 0
Date: 2023.11.12
Time: 18:13:03
Address 09: Cent. Elect. Labels:. 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000008827043
Coding: F5243F01B0141080EF00001C0000000000084E016401000300 2000000000
Shop #: WSC 01236 785 00200
VCID: 489FED273BB3F2D343-801C
Subsystem 1 - Part No: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00056595
Shop #: WSC 01236
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00150573
Shop #: WSC 01236
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 196
Mileage: 146062 km
Time Indication: 0
Date: 2024.01.15
Time: 15:36:00
Address 42: Door Elect, Driver Labels: None
Part No SW: 8P7 959 801 B HW: 8P7 959 801 B
Component: Tuer-SG H02 0020
Coding: 0004860
VCID: 4189F0031889C39B84-8014
2 Faults Found:
01333 - Door Control Module; Rear Left (J388)
Address 52: Door Elect, Pass.
Cannot be reached
Address 62: Door, Rear Left
Cannot be reached
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 21
Reset counter: 159
Mileage: 145677 km
Time Indication: 0
Date: 2023.11.12
Time: 18:13:03
Coding: 00056595
Shop #: WSC 01236
Coding: 00150573
Shop #: WSC 01236
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 196
Mileage: 146062 km
Time Indication: 0
Date: 2024.01.15
Time: 15:36:00
Coding: 0004860
2 Faults Found:
Cannot be reached
Cannot be reached
