- Joined
- Apr 22, 2015
- Messages
- 721
- Reaction score
- 76
- Points
- 28
Right side Dip Head Lamp feed Circuit -Is the switch single pole or 2 where is the split rh/lh
Another odd fault - The Right side Head lamp dip beam supply fails , light goes out , lamp fail shows on dash
turn lights off / on no change - While the lamp is out , the LEFT side works normally
Stop for while , all lights off , Try again and Dip Beam is back on ..works for weeks , then off again
Some noise on the radio when the headlights are 'first turned on- I suspect that is arcing , possibly a short time voltage drop on the supply to the radio -
The Left side light works normally , I assume the Head Light switch is single pole , Ie one feed to the L&R sides
Q where is the split Left & Right ?
Tnx Graham
Tnx Graham
