A7 Total Freak Out ! Help
Emir Demirovski
Kumanovo
Hi, my A7 last night had a total freak out while driving. I had my gearbox repaired like a month ago but i covered more than 4k kilometers since then. Last night all of a sudden i get a gearbox error, then everything else. Here you can see, my question is, is it the gearbox doing all this or something else ? I will post a VCDS scan later too.
View: https://youtube.com/shorts/wXQ4VRSxILY?si=YqpBrDWPUQv0j1c7
Lets get a scan uploaded and go from there.
I have seen when these cars light up like a Christmas tree, its ended up being the battery at fault
Reactions: Emir Demirovski
Yeah, i’m going to scan it now. I thought battery too, because it has been kinda slow cranking when turning on the last 2 weeks. Only reason i ruled it out is because i have been driving it for almost an hour when it started doing this. Either way scan is coming up
If I remember correctly, you can check the battery too:
MODULE 19 (CAN-GETAWAY)
Measure Blocks>Select GROUPS 18,19 AND 20
I'm sure there is a SOC value too but its been a while since I've had a VCDS or even a non-EV car!
Soo, after clearing DTC's it might be the common Gearbox Connector issue, i'll have to get the car up and check it for sure. But here are the scans, if you find anything you think might contribute to the problem, let me know.
I'll see the battery thing now.
  • A7 - After clearing DTC.pdf
  • A7 - Before clearing DTC.pdf
