2.0 T FSi Timing chain swap
57Avant
Oxford
Hi all, looking for advice as to the best brand recommendations for the timing chain swap on my 2.0 TFSi BUL engine.
Also, any specialist timing tools required for this job ( cam belt has been done recently prior to my purchase - documented )?
I believe this job can be done in the car ( Haynes implies it's an engine out job )
thanks for your help all..
The big question is, are you of a DIY car servicing nature?
It can be done in situ , but its an awkward one and not for those that are a bit unsure of what they are getting into.
Buy genuine oem parts where possible, and yes cam locking tool is needed as a minimum requirement, with small hands and a lot of patience.
also correct spline tool for the variator bolt, which can be problematic.
unless you have a specific reason to do it yourself, then don't , just take it to an indy and let them deal with it.
Reactions: 57Avant and NHN
Are you thinking from a preventative maintenance view point or suspected excessive wear etc.
Reactions: 57Avant
Hey, yeah, confident and competent ( i think...), I'm in the trade myself. Working in restoration just now, but spent a few years servicing and repairs, gearboxes clutches, cam belts etc. I would always get OEM, seen to many poor pattern parts..
chears for the heads up!
Reactions: Charlie Farley
