If the temp doesn’t come up to around 90° after a short while then it does sound like a faulty thermostat. Likely stuck open.
Fuel use would be higher as the engine thinks it’s cold so is pushing a more fuel rich mixture into the engine.
I’m not sure what model/engine or age of car you have but one other thing to check is your coolant system including water pump as these are common failure points
