That’s off a mk2 tts - centre bore is different to your current wheels so would need an adaptor + compared to your existing wheel the inner wheel rim will be circa 20mm closer to the suspension strut. If brakes are the same as my S5 they are a lot bigger than the ones on the mk2 TTS so that rim may not clear them either.
