I’m doing the prep for the rear brakes on my 66-plate 1.4 TFSI. I’ve proved I can slacken the slide pin bolts (7mm Allen key, but there’s no room to get a ratchet on - thanks, Audi). I’ve proved - after a serious amount of grunting and swearing - that the 14M triple square socket head bolts can be slackened (everything prevents access to everything else - thanks again, Audi). And I‘ve got an OBD tool for the electronic handbrake. So… can anyone confirm the part number for the carrier bolts, and the torque wrench setting? I’ve seen N911 689 01 as the part number, and a torque setting of 196Nm. Is that correct?
Finally, having put the EPB into pad change mode, is the piston retraction a straight push, or does one have to twist also?
