Hey guys,
Today, the electronics malfunction light kept going off until I got home. As soon as I got home, I scanned the car's ECU and I have the following codes:
What do you guys think I should do or do you guys know what could potentially be the issue? The gas tank is nearly empty too so I don't know if this could play a factor so is it fine if I drive it down to the nearest gas station to fill it up or should I not drive the vehicle at all?
Thank you!!
- P3044 - Fuel pump Short Circuit
- U1123 - Databus error value received
- U0155 - Lost Communication With Instrument Panel Cluster (IPC) Control Module
- U0121 - Lost Communication With Anti-Lock Brake System (ABS) Control Module
- U0101 - Lost Communication With TCM
Thank you!!
