A3 comfort data bus in single wire mode + central locking not working
simnn4698
Newcastle
hello I know this is a lot to read but any help is appreciated. so I've just bought a 2009 audi a3 black edition which has been having this issue with the central locking. I have read forums etc and got some idea with what's going on but I'm still struggling and need some help on what specifically to check on the car for this fault.
please note previous owner claimed that all doors, locks and key started working perfectly in the summer when it was very hot.
currently the lock button on the key works every time, the unlock button doesn't work 80% of the time. however when it does work it will work consistently until it decides to stop working all together I have only owned the car for 2 weeks and basically the unlock button worked for about 2 days when it started snowing. sounds daft but I suspect snowy weather may have reduced the overall moisture in the air....
when the unlock button worked passenger door would unlock properly. drivers door made a noise but didn't unlock with the handle (I had to manually put key in. rear left + right door made a noise but don't open.
boot/trunk works fine with boot button on key and interior unlock button.
when ignition is on. drivers door unlock/lock button works for passenger door, rear left door made a tiny noise and rear right door made a feeble noise but louder than left door.
after repeatably unlocking and locking the car I manage to get the rear right door to open with interior handle but no luck with the left.
I suspect the car has a central locking wiring issue and also the lock actuators might be stuck.
I have checked the front door wiring harnesses. The passenger harness looks perfect condition. the drivers door non of the wires were snapped however the insulation on 2 wires had opened up exposing the copper but wires are still intact and not corroded. There was also a small amount of blue corrosion on a few pins where the connector to the car is but to me didn't look severe enough to cause to be the culprit of this issue.
I've been having codes stating thermal protection for rear doors so I unbolted the lock actuator on RR and sprayed silicon grease into the lock mechanism hoping it unlock more freely. but had no luck.
rear interior door handles feel like they have barely any resistance either.
I also removed the comfort module and dried it out at home even though the circuit board looked undamaged and dry but had no luck
I also used electrical cleaner and removed most the corrosion from the pins on drivers door harness.
I haven't been able to check the rear door harness connectors due to the fact I now cant get either door to open now.
This is my vcds scan after clearing previous codes. please note the rear right door no communication I had unplugged the module and this code wasn't present beforehand.
VIN: WAUZZZ8P99A111718
Chassis Type: 8P-AU35 (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72
VIN: WAUZZZ8P99A111718 Mileage: 230960km-143511miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 1010
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 LS HW: 03L 906 022 BQ
Component: R4 2.0l TDI 0000SG 9978
Revision: 13H01--- Serial number: AUX7Z0I1FN20AU
Coding: 0000072
Shop #: WSC 26214 051 00000
VCID: 010206C158661F858D-8054
VINID: 9D196AAAA2202494410411C1206491D538
1 Fault Found:
008213 - Intake Manifold Flap Position Sensor (Bank 1)
P2015 - 000 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 230644 km
Time Indication: 0
Date: 2023.01.03
Time: 12:39:59
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Lambda: 11.0 %
Lambda: 0.8 %
Voltage: 0.304 V
Bin. Bits: 00000000
Readiness: 1 1 0 0 0
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 CD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0120
Revision: 00H35001
Coding: 13424012492300FBC81202E5922100823800
Shop #: WSC 44445 002 1048576
VCID: 76E8651DC1A8283DA8-8022
3 Faults Found:
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 118
Mileage: 230930 km
Time Indication: 0
Date: 2023.01.05
Time: 14:12:04
Freeze Frame:
Count: 7
Count: 0
Count: 4608
Count: 65
Count: 51565
Count: 0
Count: 0
Count: 0
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 1
Fault Frequency: 1
Reset counter: 78
Mileage: 230923 km
Time Indication: 0
Date: 2023.01.05
Time: 12:46:50
Freeze Frame:
Count: 0
Count: 0
Count: 4608
Count: 69
Count: 50454
Count: 0
Count: 0
Count: 0
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 78
Mileage: 230923 km
Time Indication: 0
Date: 2023.01.05
Time: 12:47:20
Freeze Frame:
Count: 3
Count: 0
Count: 4608
Count: 83
Count: 50444
Count: 58075
Count: 0
Count: 0
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BH HW: 8P0 820 043 BH
Component: KlimavollautomatH09 0100
Revision: 000832 Serial number: 8P0820043BH
Shop #: WSC 00000 000 00000
VCID: 73EE5C0912DA3D158F-8026
No fault code found.
Address 09: Cent. Elect. Labels:. 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000009346390
Coding: 118A0F81B0141380EF00000A0000000000084E0564060403642000000000
Shop #: WSC 06314 000 08192
VCID: 4894DBE53BDCEECD0A-801C
Subsystem 1 - Part No: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00056595
Shop #: WSC 06314
1 Fault Found:
01334 - Door Control Module; Rear Right (J389)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 119
Mileage: 230965 km
Time Indication: 0
Date: 2023.01.05
Time: 18:22:00
Freeze Frame:
ON
Voltage: 13.75 V
OFF
ON
OFF
OFF
OFF
Address 15: Airbags (J234) Labels:* 8P0-959-655-10.clb
Part No SW: 8P0 959 655 J HW: 8P0 959 655 J
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003CA004WR8A
Coding: 303142383038303030374A55305238503053
Shop #: WSC 06314 000 00000
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 4992DEE1E8D617C515-801C
Crash sensor for side airbag: driver side:
Serial number: 3572DRB4000083251A7M
Front Passenger's Side Airbag Crash Sensor:
Serial number: 3582DRB40000832D125L
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 35128RB40000498317CJ
Passenger side rear thorax airbag crash sensor:
Serial number: 35228RB400004A9EDA5+
Crash sensor for front airbag: driver side:
Serial number: 35547RB400004B1409BK
Crash sensor for front airbag: front passenger side:
Serial number: 35647RB400004B145C0I
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0002012
VCID: 4182C6C118E6DF85CD-8014
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H06 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 C HW: 8P0 920 982 C
Component: KOMBIINSTR. VDO H19 0860
Revision: D0H19007 Serial number: 2241I007016184
Coding: 0004428
Shop #: WSC 12345 067 57207
VCID: 3972AE217036874585-806C
Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533__Gateway H16 0210
Revision: H16 Serial number: 3400K0913007C6
Coding: E9817F06000202002103
Shop #: WSC 12345 123 12345
VCID: 3776A8194622913573-8062
2 Faults Found:
00470 - Company Comfort Databus in Single Wire
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 28
Reset counter: 79
Mileage: 230923 km
Time Indication: 0
Date: 2023.01.05
Time: 12:34:41
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 119
Mileage: 230965 km
Time Indication: 0
Date: 2023.01.05
Time: 18:22:59
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H19007 Serial number: AUX7Z0I1FN20AU
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
Component: Tuer-SG H03 0060
Coding: 0000692
VCID: 438ECCC902FACD95DF-8016
2 Faults Found:
01552 - Motor for Central Locking; Drivers Door (V56); Lock
012 - Electrical Fault in Circuit
00928 - Locking Module for Central Locking; Front Driver Side (F220)
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 E
Component: EPS_ZFLS Kl. 233 2501
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2C5C87758F6422ED0E-8078
1 Fault Found:
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 5
Reset counter: 129
Mileage: 230962 km
Time Indication: 0
Date: 2023.01.05
Time: 18:03:29
Freeze Frame:
Voltage: 14.00 V
DU
Temperature: 16.0°C
RPM: 3046 /min
Speed: 48.0 km/h
Speed: 48.0 km/h
Count: 0
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 J
Component: KSG H11 0080
Coding: 1980200002186D0985054C9FC637
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
2 Faults Found:
01038 - Central Locking Thermal Protection
000 - - - Intermittent
00332 - Control Circuit for Tank Flap
007 - Short to Ground
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Coding: 0000692
VCID: 448CCFD507F4CAADE6-8010
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P3 907 357
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000013
VCID: 7AF0712D35B04C5DCC-802E
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 119
Mileage: 230920 km
Time Indication: 0
Date: 2023.01.05
Time: 12:46:55
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 186 P HW: 8P0 035 186 P
Component: R Concert2+ H03 0270
Revision: 00H03000 Serial number: AUZ1Z3I9722982
Coding: 0310201
VCID: 3F86C0396E12A975BB-806A
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
Component: Tuer-SG H04 0040
Coding: 0000144
Shop #: WSC 06314 000 1012544
3 Faults Found:
01554 - Motors for Central Locking; Rear Doors; Lock
00098 - Rear Left Central Locking (Safe) Motor (V163)
012 - Electrical Fault in Circuit - Intermittent
00930 - Locking Module for Central Locking; Rear Left (F222)
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
Coding: 0000144
VCID: 4280C9CD1DE0C49DD4-8016
3 Faults Found:
00099 - Rear Right Central Locking (Safe) Motor (V164)
00931 - Locking Module for Central Locking; Rear Right (F223)
End-------------------------(Elapsed Time: 01:51)--------------------------
I purchased wiring diagrams for the central locking but struggling to make sense of it all.
am I correct in that every door module connects to the canbus and then the comfort module connects to canbus or do the door modules wire up to the comfort module which then connects to the canbus?
specifically what modules could be faulty?
i read that the drivers door module can cause issues to central locking but how would i confirm that it needs replacing?
any help is appreciated, I'm not a professional at fixing cars but a simple DIYer so apologies if i seem confusing.
thank you.
I have attached photos of drivers door harness which have the corrosion.
1stly clear codes with Vcds and then do another Autoscan just incse some off ur codes are old ones.
Then report bk
Then report bk
What software is ur Vcds running or friends
Hello bud thanks for responding. Just at work il let you know in an hour or so once am home. Il clear all my codes, try to unlock the car and do a scan and post it in here.
The corrosion looks quite bad on that door connector. It will cause intermittent issues and it's possible sometimes for the complete pin to snap off. The CAN bus does connect to each of the door modules , the CAN bus pair will be a thin pair of wires that are twisted together, The CAN bus normally needs both wires to work but it can work in a single wire mode but not as well. Also look for broken wires in the door harness , you can see in the picture cuts in the insulatiuon, because the wires are flexed every time the door is opened eventually sometimes some will snap. You need to do a continuity test from the plug to the modules in the door.
The door locking actuators also fail and go intermeittent.
1674389457854
Reactions: ch1z64
just fixed my abs code so they have gone.
just done a new scan, i clicked the unlock and lock button before scanning car to show up any associated codes.
Monday,23,January,2023,21:03:30:28437
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 22.10.0.1 (x64)
Data version: 20221026 DS344.0
www.Ross-Tech.com
VIN: WAUZZZ8P99A111718 License Plate: NA09 ORK 5
Mileage: 231520km-143859mi Repair Order:
VIN: WAUZZZ8P99A111718 Mileage: 231520km-143859miles
03-ABS Brakes -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
Coding: 0000072
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 231225 km
Time Indication: 0
Date: 2023.01.09
Time: 20:11:13
Freeze Frame:
RPM: 851 /min
Speed: 4.0 km/h
Load: 0.0 %
Lambda: 11.0 %
Lambda: 0.8 %
Voltage: 0.304 V
Bin. Bits: 00000000
Revision: 00H35001
Coding: 00056595
Shop #: WSC 06314
Coding: 0002012
Coding: 0004428
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 24
Reset counter: 94
Mileage: 231505 km
Time Indication: 0
Date: 2023.01.12
Time: 14:53:36
Coding: 0000692
2 Faults Found:
Revision: 00H15000
1 Fault Found:
Coding: 0000692
Coding: 0000013
Coding: 0310201
Coding: 0000144
1 Fault Found:
Coding: 0000144
2 Faults Found:
End-------------------------(Elapsed Time: 01:58)--------------------------
Update : even though the lock button always worked. I noticed the red led light on both of my keys wouldn't light up.
I thought id change the battery in one key. Now unlock for that key has worked ever since.
Trying both keys together figured id put the unlock not working down to a bad key battery.
I still have the other issues though where it only unlocks the passenger door but can finally rule out the the key issue.
Now just need to figure out why the other doors arent opening. Going to do some continuity testing between various doors.
Also when i try to use the rear washer it makes the motor noise but no screenwash comes out.... not sure exactly but i watched a video and the guy said the water line runs through the right side of the car next to the wires.... thinking something may be going on there.... need to do some more investigating.
Positive progression on the car using infomation from this link
Iv disconnected the HVAC yellow far left wiring loom connector which is linked to the comfort databus and now my comfort databus has gone into 2 wire mode which is brilliant. Will need to repair/replace the hvac unit to bring back the full network.
Restored some functionally to the doors... rear left door now opens with key and door.
The (electrical fault in circuit) code has gone but still an impausible single code.
Drivers and rear right are still behaving erratically but glad to be getting somewhere.
Reactions: ch1z64
FIXED CANBUS SINGLE WIRE ISSUE
So I unplugged the hvac unit which caused the canbus to go back into 2 wire mode. Instead of wasting money buying a new module I took it out which was simple to do and inspected the circuit board.
Looking closely I noticed one of the components had came off the solder joints.
I carefully soldered on a low heat and connected it back together. Installed it in the car. Code was still there. Took it out again touched my voltmeter to the component and circuit board on one connection and found I had not repaired it correctly on one sprong so resoldered. Back in car and codes not came back since.
I bet this is what happens when the hvac goes bad so dont waste ur money guys it was easy to fix.
coincidentially returned functionality in my rear left door. All the others are still misbehaving however canbus is back online :)
20230210 004334
Reactions: coupa and curtis92
Just wanted to conclude
1. Door unlocking issue was cause by a low key battery
2. single wire mode was caused by a component on HVAC Unit which had came of the soldered joint.
3. I've fixed all my doors. Every single actuator was bad. Dont even think its worth trying to fix them cause the mechanism is so fiddly and confusing i just used £30 actuators from ebay and they work a treat.
I hope this can help someone. Best of luck guys.
Could replacing hvac unit also fix the issue I don’t have soldering iron and would take same amount of time in post
