Heated Rear Screen Not Working
fireman099
Warwickshire
Hi
The heated rear screen on my 2017 B9 Avant isn’t working. First point of call is obvs the fuse but on checking the manual against the actual fuses in the left side of the boot they bear no resemblance?
Can anyone help, or shed any light on this ? Not sure how i’ve got a manual with the wrong fuse board in?
TIA
Neil
Just checked my manual and it says bank B is not used so would assume that would explain why that is missing in your photo. Other than that it looks a match so would assume the heated rear screen fuse is the bottom one in in the left bank i.e. the one rated 30A with all empty slots below it. I'd go check my but dark, wet, car parked in garage and cba.
Thanks for that, i checked that 30 A and seems fine. if it’s not too much trouble would you mind send me a pic of the fuse layouts from you manual, no idea why mine is so wrong!
