Permanent Bulb Warning light
nade
I've got a bulb warning light shown on the dashboard, but I don't see any bulbs that have gone out. The cluster doesn't show any specific light that had gone out, just a fixed bulb out sign. VCDS/OBD doesn't show anything either in the logs.
Any ideas how I can get this removed? Thanks
When you turn on the ignition it tells you which bulb, so watch it closely. Also, you can try the ignition on, then push either the left or right plastic sticking coming out the dash and it tells you which one. If that's wrong someone will correct me lol Mine was the n/s rear lamp connector oxidised
Reactions: nade
Thanks mate, it’s showing now using the stalk on the cluster as you’d mentioned. Usually it shows up on It’s own, strange.
... I have a bulb out (driver's side driving light) but no dash warning :shrug:
