Floppy lining
AlS3BE
Edinburgh
Just a quick question
The lining on the bonnet is a bit floppy and lost all rigidity in the bottom left corner.
can this be fixed?
If not, anyone got the part number and price for new one?
cheers
341E355F 5520 4DF1 B3AA E37B8CF410EC
I would try with inserting a couple of thin metal wires into it.
Reactions: AlS3BE
My A3 8v got the very same problem
Gesendet von meinem VOG-L29 mit Tapatalk
it’s odd. The rest of the lining is thick cardboard but the floppy part is like soft sponge like material. It’s dry and not wet or damp. Material just went soft
Mine has done the same. I believe it's due to heat overtime causing the material to deform and shrink which means it doesn't sit in the gaps. A new piece is around £60 from audi which is probably the best way to go about it.
Reactions: AlS3BE
Might remove it and see if it makes any difference to noise. Car is the family bus so can’t be too noisy on long journeys
It will make no difference what so ever (IMO) taking it out - its added weight and with it slopping, a danger - it isn't likely to catch on anything in the engine but I would rip it out to avoid the risk
Reactions: AlS3BE
