I first noticed I have the fault code below not long after changing the car battery (I did not check before changing the battery). I seen a few threads/vids suggesting the battery might need coded following being changed. I ran through the video below and I'm now suspecting the battery doesn't need coding for my car. Does anyone know for sure?
Have 61 battery reg but get no response
Have 71 battery charger but get no response
Long adaption is greyed out in CAN Gateway
005634 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
Note I also now have the following fault codes. I've just tightening the metal pipe going into the HPFP now so hoping this what is causing the fuel pressure codes. Also car runs fine.
00135 - Fuel Rail/System Pressure
P0087 - 002 - Too Low - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 113575 km
Time Indication: 0
Date: 2022.04.21
Time: 12:28:03
Freeze Frame:
RPM: 851 /min
Load: 26.3 %
Speed: 0.0 km/h
Temperature: 79.0°C
Temperature: 43.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.716 V
000135 - Fuel Rail/System Pressure
P0087 - 008 - Too Low - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 113575 km
Time Indication: 0
Date: 2022.04.21
Time: 12:28:13
Freeze Frame:
RPM: 802 /min
Load: 20.8 %
Speed: 0.0 km/h
Temperature: 79.0°C
Temperature: 43.0°C
Voltage: 13.716 V
001672 - ECM Power Relay Load Circuit
P0688 - 002 - Open Circuit - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 113745 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 16.0°C
Temperature: 19.0°C
Voltage: 0.000 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Voltage: 0.000 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 113575 km
Time Indication: 0
Date: 2022.04.21
Time: 12:28:03
Freeze Frame:
RPM: 851 /min
Load: 26.3 %
Speed: 0.0 km/h
Temperature: 79.0°C
Temperature: 43.0°C
Voltage: 13.716 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 113575 km
Time Indication: 0
Date: 2022.04.21
Time: 12:28:13
Freeze Frame:
RPM: 802 /min
Load: 20.8 %
Speed: 0.0 km/h
Temperature: 79.0°C
Temperature: 43.0°C
Voltage: 13.716 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 113745 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 16.0°C
Temperature: 19.0°C
Voltage: 0.000 V
