Audi A3 brake upgrade from 280mm to 312mm
Mrkishaa
Dugo Selo
I have a question, OEM the car has 1ZF 280mm discs with FS-III calipers, does someone know what parts i need to change to fit the 312mm brake disc. Is it only the brake caliper and the caliper carrier that I need to change or is there something else?
Unfortunately, the calliper carrier for these callipers is an integral part of the hub and so this needs to be changed as well making it a bigger job rather than just unbolting the carrier from the hub as found on the brakes with the larger discs.
Reactions: samisnake
Ohh thank you. I tought at first that only changing the carrier would make the upgrade possible.
