Hi!
I have encountered some problems with my fuel injectors.
The car runs great at idle, but when I try to accelerate ut to approximately 3000 rpm the ECU throws these codes (Sometimes juts group A, sometimes just group B and sometimes both;
5060 - Supply Voltage for Fuel Injector Group A
P2146 00 [167] - Open Circuit
MIL ON - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 353429 km
Date: 2022.05.12
Time: 18:02:59
Engine RPM: 2228.00 /min
Normed load value: 65.1 %
Vehicle speed: 52 km/h
Coolant temperature: 36 °C
Intake air temperature: 17 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 14.160 V
Unlearning counter according OBD: 40
Allowed number of injections-Bits 0-7: 3
Injection release status-Bits 0-7: 56
Desired injection characteristic-Bits 0-7: 56
Mean injection quantity: 43.74 mg/stroke
Rail pressure regulation: status-Bits 0-7: 5
Fuel high-pressure: actual value: 1235500 hPa
Control Module temperature: 26.8 °C
5061 - Supply Voltage for Fuel Injector Group B
P2149 00 [167] - Open Circuit
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 353429 km
Date: 2022.05.12
Time: 18:02:59
Engine RPM: 2217.00 /min
Normed load value: 72.2 %
Voltage terminal 30: 14.060 V
Mean injection quantity: 43.10 mg/stroke
Fuel high-pressure: actual value: 1262300 hPa
So far I have;
-Changed diesel filter
-Replaced injector seals and washers
-Cleaned the injector nozzles
-Checked the wiring from ECU to each injector connector for broken cables
-Inspected the wiring loom for ECU to each injector
-Changed two injectors that I suspected to be bad
-Checked ECU ground points
-Measured the resistance of each injector - about 139-144 kOhms
-Completed VCDS injector test - no problems there.
I am starting to think there could be something wrong with the ECU and I have contacted some local shops about checking it for me.
Have any of you gotten a problem like this?
Any help would be great
Full scan:
Saturday,14,May,2022,15:44:18:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.9.0.1 (x64)
Data version: 20210824 DS330.0
www.Ross-Tech.com
VIN: WAUZZZ4G2CN039590 License Plate: DR55233
Mileage: 353442km-219618mi Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 06 08 09 0E 10 13 15 16 17 19 20 28 34 36 3B 3C
42 44 46 47 52 53 55 56 5F 62 69 6C 6D 72 85 88 89 8B 8E 8F
90
VIN: WAUZZZ4G2CN039590 Mileage: 353442km-219618miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
20-High Beam Assist. -- Status: Cannot be reached 0100
28-HVAC, Rear -- Status: Malfunction 0010
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
3B-Sensor Elect. -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
85-On Board Cam. -- Status: OK 0000
88-Multicont. Seat Driver -- Status: OK 0000
89-Multicont. Seat Pass. -- Status: OK 0000
8B-Adaptive Cruise 2 -- Status: Malfunction 0010
8E-Image Processing -- Status: OK 0000
8F-Pretens. Frt Left -- Status: OK 0000
90-Pretens. Frt Right -- Status: OK 0000
Address 01: Engine (J623-CDUC) Labels:. 059-907-401-V2.clb
Part No SW: 4G0 907 401 F HW: 4G0 907 401
Component: 3.0TDI EDC17 X37 0004
Revision: 53X37--- CVN: 6C866BA4
Coding: 12254012057601020000
Shop #: WSC 27669 141 13150
ASAM Dataset: EV_ECM30TDI0114G0907401F 001004
ROD: EV_ECM30TDI0114G0907401F.rod
VCID: 2643439F59E704B918-8072
VINID: 9D196AAAA1170937800C914900B2FBCBD6
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 353442 km
Date: 2022.05.14
Time: 15:32:14
Engine RPM: 2552.50 /min
Normed load value: 15.7 %
Vehicle speed: 0 km/h
Coolant temperature: 84 °C
Intake air temperature: 48 °C
Ambient air pressure: 1000 mbar
Mean injection quantity: 6.98 mg/stroke
Rail pressure regulation: status-Bits 0-7: 18
Fuel high-pressure: actual value: 1117300 hPa
Control Module temperature: 80.6 °C
Readiness: 0 0 0 0 1
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 4G1 927 156 B HW: 0B5 927 156 F
Component: 0B5 30 TDIRdW H10 0001
Revision: --H10--- Serial number: 0000001266 CVN: 0000FA13
Coding: 000001
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_TCMDL501 A02087
ROD: EV_TCMDL501.rod
VCID: 2C57B1B7470B3EE9CE-8078
No fault code found.
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 G HW: 4G0 907 379 G
Component: ESP PREMIUM H09 0250
Revision: -------- Serial number: --------------
Coding: 27A6C701E465E380FB00
ASAM Dataset: EV_ESPPremiAU57X 004017
ROD: EV_ESPPremiAU57X_004_AU57.rod
VCID: 356194D394417F21A1-8060
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 BP HW: 4H0 907 064 BP
Component: BCM2 2.0 H31 0330
Revision: 00002001
Coding: 05A92F06000000000000
VCID: 78FF5DE7CBD342497A-802C
Address 06: Seat Mem. Pass (J521) Labels: None
Part No SW: 4G8 959 760 B HW: 4G8 959 760 B
Component: MEM-BFS H04 0153
Revision: AA000000 Serial number: 00000006315829
Coding: 0018320000006201000001010101112030303333283333
VCID: 397998E3B0599B4145-806C
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 K HW: 4G0 820 043 K
Component: KLIMA 4 ZONEN H11 0062
Serial number: 08081100040224
Coding: 360200B82C
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_AirCondiComfoUDS 002033
ROD: EV_AirCondiComfoUDS_002.rod
VCID: 275D4E9B5EED1DB123-8072
1 Fault Found:
0378 - Coolant Circulation Pump
B10D0 04 [008] - Internal System Fault
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 155
Mileage: 353423 km
Date: 2022.05.08
Time: 14:54:23
Voltage terminal 30: 13.44 V
Outside temperature: 17.0 °C
Inside temperature: 19.21 °C
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 BF HW: 4H0 907 063 F
Component: BCM1 2.0 H12 0100
Revision: 20012002 Serial number: 00000001161049
Coding: 0200201150F48FE2C9810083A0001908CF9CE7082E080101000008402101
Shop #: WSC 12345 123 61029
VCID: 6DD17CB3B491F7E199-8038
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
Component: WWS57X 110716 H35 0051
Serial number: 110718040715
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 11588204
Coding: 02512B
Subsystem 3 - Part No SW: 4G0 941 531 E HW: 4G0 941 531 E
Component: E1 - LDS H07 0044
Serial number: 28 07 2011 00000611
Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H02 0002
Serial number: C8288CB5000000000001
1 Fault Found:
03395 - Control Module for High Beam Assistant
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 113
Mileage: 353411 km
Time Indication: 0
Date: 2022.04.23
Time: 21:08:00
Address 0E: Media Player 1 (R161) Labels: None
Part No SW: 4H0 035 108 F HW: 4H0 035 108
Component: DVDCAlpine H42 0200
Revision: AA001001
Coding: 010000
VCID: 23455A8B22D5F1917F-8076
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 L HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0043
Revision: 11001001 Serial number: 55901120301240
Coding: 292B07
ASAM Dataset: EV_EPHVA18AU57X0000 002005
ROD: EV_EPHVA18AU57X0000_002_AU57.rod
VCID: 3B7582EBB265A95157-806E
Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb
Part No SW: 4G0 907 561 HW: 4G0 907 561
Component: ACC3 H15 0160
Serial number: 00000000000000
Coding: 3F04010202
ASAM Dataset: EV_AdaptCruisContrAU57X 001003
ROD: EV_AdaptCruisContrAU57X_001.rod
VCID: 67DD0E9B9E6DDDB1E3-8032
3 Faults Found:
11264 - Sensor for Automatic Distance Regulation
C110B 49 [008] - Internal Electronic Failure
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 156
Mileage: 353323 km
Date: 2022.04.19
Time: 07:10:13
Control Module temperature: 11 °C
Voltage terminal 15: 13.842 V
Velocity_vehicle_reference: 17.89 m/s
Longitudinal_acceleration_vehicle_reference: 0.38 m/s²
82688 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 156
Mileage: 353405 km
Date: 2022.04.21
Time: 15:53:14
Control Module temperature: 19 °C
Voltage terminal 15: 11.798 V
Velocity_vehicle_reference: -0.01 m/s
Longitudinal_acceleration_vehicle_reference: 0.00 m/s²
92416 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 156
Mileage: 353323 km
Date: 2022.04.19
Time: 07:10:13
Voltage terminal 15: 14.540 V
Velocity_vehicle_reference: 17.82 m/s
Longitudinal_acceleration_vehicle_reference: 0.40 m/s²
Address 15: Airbags (J234) Labels:* 4H0-959-655.clb
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H40 0040
Revision: -------- Serial number: 003JG003L3VA
Coding: 30323436313330303335554A304C34473053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_VW51.rod
VCID: 366393DF89477439A8-8062
Crash sensor for side airbag: driver side:
Serial number: 3575HRB40590N3MGEOG$
Front Passenger's Side Airbag Crash Sensor:
Serial number: 3585HRB40690H9221PF.
Rear Side Airbag Crash Sensor (on driver's side):
Serial number: 3515JRB405N0LCOQFHNQ
Passenger side rear thorax airbag crash sensor:
Serial number: 3525JRB404V0L2V2GHD+
Crash sensor for front airbag: driver side:
Serial number: 3554VRB404V0LCOQEGBY
Crash sensor for front airbag: front passenger side:
Serial number: 3564VRB404T0LCOQI9H-
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4H0 953 568 G HW: 4H0 953 568 G
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90372KGP000GC
Coding: 0000DD
VCID: 377D9EDB864D8D31B3-8062
Subsystem 1 - Part No SW: 4G0 951 528 C HW: 4G0 951 528 C
Component: E221 - MFL H07 0009
Serial number: 08 06 2011 11141928
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 931 J HW: 4G8 920 931 J
Component: TDieRdwAcc H71 0375
Revision: 26181114 Serial number: 658040811592013
Coding: 038F11005F050008000000
ASAM Dataset: EV_RBD4K 004040
ROD: EV_RBD4K_AU57.rod
Address 19: CAN Gateway (J533) Labels:| 4H0-907-468.clb
Part No SW: 4G0 907 468 E HW: 4G0 907 468 A
Component: J533--Gateway H08 0213
Revision: -------- Serial number: 00000000216817
Coding: 00CD077D00
GVL: FFEFE94CFEE760CD40
ASAM Dataset: EV_GatewUDS 001025
ROD: EV_GatewUDS_AU57.rod
VCID: 326BAFCF652F681984-8066
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005650169754
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
Component: J532_DCDCStab H05 0006
Serial number: 11211001937021200410
3 Faults Found:
5701 - High Beam Assistant Control Module
U1070 00 [009] - No Communication
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 113
Mileage: 353413 km
Date: 2022.05.05
Time: 20:26:43
Voltage terminal 30: 14.3 V
Voltage terminal 15: 14.2 V
Control Module temperature: 31 °C
System status: Terminal 15 on
IN ESP_standstill flag: standstill detected
Engine running: On
IN ZAS_Te_X: On
Terminal 15 status via CAN: On
Terminal 15 status: On
Datenfeld: 0
12290 - Quiescent Current
U1406 00 [008] - Too High
Freeze Frame:
Fault Priority: 7
Fault Frequency: 7
Reset counter: 156
Mileage: 353426 km
Date: 2022.05.10
Time: 20:15:14
Voltage terminal 30: 12.1 V
Voltage terminal 15: 0.0 V
System status: LIN_active
IN ESP_standstill flag: no standstill detected
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status via CAN: OFF
Terminal 15 status: OFF
Datenfeld: 0
12291 - Energy Management Active
U140B 00 [008] - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 156
Mileage: 353413 km
Date: 2022.05.06
Time: 19:31:42
Voltage terminal 30: 9.1 V
Voltage terminal 15: 9.1 V
Control Module temperature: 28 °C
Engine running: OFF
IN ZAS_Te_X: OFF
Datenfeld: 1
Address 20: High Beam Assist.
Cannot be reached
Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb
Part No SW: 4G0 919 158 D HW: 4G0 919 158 D
Component: KLIMA FOND H07 0062
Serial number: 04081100040774
Coding: 00
ASAM Dataset: EV_ClimaContrUnitRearUDS 002015
ROD: EV_ClimaContrUnitRearUDS_002.rod
VCID: 306FA5C76B235A09F2-8064
2 Faults Found:
0033 - Motor for Rear Right Upper Body Vent
B10D4 22 [008] - Signal Amplitude Too High
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 153
Mileage: 353335 km
Date: 2022.04.19
Time: 15:46:44
Voltage terminal 30: 14.58 V
Outside temperature: 12.5 °C
Right Rear Upper Body Vent Motor-Act.val.: 11701
Right Rear Upper Body Vent Motor-Target value: 11701
Right Rear Upper Body Vent Motor-Stop open: 11396
Right Rear Upper Body Vent Motor-Stop closed: 10000
0034 - Motor for Rear Right Upper Body Vent
B10D4 21 [008] - Signal Amplitude Too Low
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 153
Mileage: 353407 km
Date: 2022.04.21
Time: 19:44:08
Voltage terminal 30: 11.97 V
Outside temperature: 19.0 °C
Right Rear Upper Body Vent Motor-Act.val.: 9849
Right Rear Upper Body Vent Motor-Target value: 9849
Address 34: Level Control (J197) Labels:. 4G0-907-553.clb
Part No SW: 4G0 907 553 C HW: 4G0 907 553
Component: LUFE-DAEMPFER H17 0779
Coding: 008003
ASAM Dataset: EV_AirSuspe 003022
ROD: EV_AirSuspe_VW51.rod
VCID: 2B55B2AB420539D1C7-807E
1 Fault Found:
403200 - Function Shut-Off Active
C10C8 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 156
Mileage: 353426 km
Date: 2022.05.10
Time: 18:10:29
Address 36: Seat Mem. Drvr (J136) Labels: None
Component: MEM-FS H04 0153
Revision: AA000000 Serial number: 00000006315846
Coding: 00183B0000016201000001010101112030303333203333
Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
Part No SW: 4G0 907 637 B HW: 4G0 907 637 B
Component: SARA 6D H02 0004
Revision: -------- Serial number: EJ1BPA4201M8K80
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA_006.rod
VCID: 2D51BCB37C1137E1D9-8078
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 4G0 907 566 D HW: 4G0 907 566
Component: J769 SWA MasterH01 0020
Revision: 00H01000 Serial number: 6PZ 010 287-03
Coding: 0010102
Shop #: WSC 00550 550 12345
VCID: 306FA5C7A3235A09F2-8064
Subsystem 1 - Part No: 4G0 907 568 D
Component: J770 SWA Slave H01 0040
Subsystem 2 - Serial number: 6PZ 010 287-23
Subsystem 3 - Serial number: 5F13.08.1200H010003CF20419ÿ
Subsystem 4 - Serial number: F20419ÿ
Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb
Part No SW: 4G8 959 793 D HW: 4G8 959 793
Component: TSG FA H05 0212
Coding: 011F16205E00628202080013
VCID: 4189F003D889C3810D-8014
Address 44: Steering Assist (J500) Labels:| 4G0-909-144.clb
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H33 0010
Revision: 00001000 Serial number: 0029129703
Coding: 101001010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0155198846
Coding: 01000E2020B93495832009842E0304000000000000000000000000000000
Subsystem 1 - Part No SW: 4G9 959 591 HW: 8V3 959 591
Component: J245 PS20.006 H02 0007
Serial number: WOO11875523
Coding: 001F00
Subsystem 2 - Part No SW: 4G0 947 135 K HW: 4G0 947 135
Component: Dachelektroni H10 0100
Serial number: 0000000AP00000293824
Coding: 010000
Subsystem 3 - Part No SW: 4G9 959 591 HW: 8V3 959 591
Component: J394 PS20.006 H02 0007
Serial number: WOO11867513
Coding: 001F00
Subsystem 4 - Part No SW: 3AA 962 243 HW: 3AA 962 243
Component: GEB.F.Heckoef H12 0714
Serial number: 98003046
2 Faults Found:
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 108
Mileage: 353333 km
Time Indication: 0
Date: 2022.04.19
Time: 07:20:04
02616 - Fuel Tank Cap; Unlock
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 108
Mileage: 353333 km
Time Indication: 0
Date: 2022.04.19
Time: 07:20:36
Address 47: Sound System (J525) Labels: None
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007000 Serial number: 00000000015034
Coding: 030000
Shop #: WSC 27669 141 12695
VCID: 1D316C7304B1C76149-8048
Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb
Part No SW: 4G8 959 792 E HW: 4G8 959 792 A
Component: TSG BF H05 0212
Coding: 011F16205E00628202080002
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000119423
ASAM Dataset: EV_ParkiBrake 001022
ROD: EV_ParkiBrake_VW51.rod
VCID: 2A5BB7AF4DFF20D93C-807E
Address 55: Headlight Range (J431) Labels:| 4H4-907-357-V1.clb
Part No SW: 4H4 907 357 A HW: 4H4 907 357 A
Component: ....AFS13.... H01 0012
Serial number: 110802-0004-010
Coding: 11226F33F91AEB00
ASAM Dataset: EV_AdvanFrontSyste 005001
ROD: EV_AdvanFrontSyste_AU21.rod
Left Headlamp Power Output Stage:
H02 0008
Coding: 1D0000
Right Headlamp Power Output Stage:
H02 0008
Coding: 1D0000
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G1 035 053 J HW: 4G1 035 053
Component: Radio U Basic H41 0133
Revision: AB001007 Serial number: 049HZ0BB012148
Coding: 010003010000000001
VCID: 2643439F51E704B918-8072
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 4G0 035 670 Q HW: 4G0 035 670
Component: H-BNT-EU H47 1072
Revision: -------- Serial number: 428H-0B7520347
Coding: 050100010003F9EF7D30EB3E00000003080001000000000000
VCID: 3169A0C368295301FD-8064
Subsystem 1 - Part No: 8R0 060 884 FK
Component: EUR 2018/2019 2702
Subsystem 2 - Part No SW: 4F0 910 393 AH HW: 4F0 862 393 E
Component: BTHS H25 0750
Serial number: P11001312569
Subsystem 3 - Part No SW: 4G0 919 605 HW: 4G0 919 605 A
Component: DU8 C7 SV H42 0021
Serial number: AUZ8ZDB1301A3UI
Subsystem 4 - Part No SW: 4G1 919 610 C HW: 4G1 919 610 A
Component: E380 BDT C7 H08 0204
Serial number: 90349KH20006C
Subsystem 5 - Part No: 8R0 060 961 B
Component: CD-Database 3371
2 Faults Found:
03276 - Please Check Software Version Management
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 107
Mileage: 353324 km
Time Indication: 0
Date: 2022.04.19
Time: 07:10:30
Freeze Frame:
Text: DUA009,Front,M,0,0,6
03623 - Invalid Security/Release Code
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 107
Mileage: 353324 km
Time Indication: 0
Date: 2022.04.19
Time: 07:10:30
Freeze Frame:
Hex Value: 0x0004
Hex Value: 0x0009
Count: 7
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4G8 959 795 E HW: 4G8 959 795 A
Component: TSG HL H04 0212
Coding: 010F14204000628202080002
VCID: 4487F917C79BD6A926-8010
Address 69: Trailer (J345) Labels:. 4G8-907-383-V1.clb
Part No SW: 4G8 907 383 HW: 4G8 907 383
Component: Anhaenger H07 0100
Revision: 5G001001 Serial number: 00000140127722
Coding: 0109080000000000
VCID: 71E960C3A8A91301BD-8024
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4G0 907 441 B HW: 4H0 907 441
Component: SG Rueckfahrkamera 0061
Revision: --H04--- Serial number: 525 PA8J1XG9NZ
Coding: 1090005
VCID: 2643439F91E704B918-8072
Address 6D: Trunk Elect. (----) Labels:* Redir Fail!
Part No SW: 4G9 959 107 A HW: 4G9 959 107 A
Component: HDSG-Modul H03 0139
Revision: 14003001 Serial number: 202100071
Coding: 097205C011
ASAM Dataset: EV_HDSGAu572 001001
ROD: EV_HDSGAu571.rod
VCID: 3467A9D79F3B662996-8060
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H04 0212
Address 85: On Board Cam. (J852) Labels:| 7P6-907-217.clb
Part No SW: 4G0 907 217 HW: 4H0 907 217 A
Component: DPC-SG H24 0036
Revision: -------- Serial number: 262130025421000
Coding: EE060000
ASAM Dataset: EV_OnBoardCamerDPC 001007
ROD: EV_OnBoardCamerDPC.rod
VCID: 65C104936461CFA1D1-8030
Address 88: Multicont. Seat Driver (J873) Labels:* None
Part No SW: 4H0 907 182 H HW: 4H0 907 182 H
Component: IVB H07 0042
Serial number: 00001145092701
Coding: 662FF2
ASAM Dataset: EV_IVBDriveSideFrnt 001003
ROD: EV_IVBDriveSideFrnt.rod
VCID: 2F6DA6BB761D45F1EB-807A
Address 89: Multicont. Seat Pass. (J872) Labels:* None
Serial number: 00001145097501
Coding: 262FF2
ASAM Dataset: EV_IVBPasseSideFrnt 001003
Address 8B: Adaptive Cruise 2 (J428) Labels:| 4H0-907-561.clb
Part No SW: 4G0 907 541 HW: 4G0 907 541
Component: ACC3 H21 0160
Coding: 3F04010202
Shop #: WSC 24906 003 1048576
ASAM Dataset: EV_AdaptCruisContr2AU57X 001002
ROD: EV_AdaptCruisContr2AU57X_001.rod
1 Fault Found:
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 156
Mileage: 353425 km
Date: 2022.05.10
Time: 17:44:41
Control Module temperature: 23 °C
Voltage terminal 15: 14.493 V
Velocity_vehicle_reference: 7.78 m/s
Longitudinal_acceleration_vehicle_reference: 0.11 m/s²
Address 8E: Image Processing (J851) Labels:| 4H0-907-107-V2.clb
Part No SW: 4G0 907 107 B HW: 4H0 907 107
Component: BV-SG H29 0034
Serial number: 000040182407117
Coding: 01C0BB001111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
VCID: 2541449324E10FA111-8070
Address 8F: Pretens. Frt Left (J854) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 945 HW: 4H0 980 945
Component: RGS-VL H05 0070
Coding: 0066E608031F037E070308014240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 6FED66BBB69D05F1AB-803A
Address 90: Pretens. Frt Right (J855) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 946 HW: 4H0 980 946
Component: RGS-VR H05 0070
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 70EF65C7ABA31A09B2-8024
End-------------------------(Elapsed Time: 07:09)--------------------------
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 353429 km
Date: 2022.05.12
Time: 18:02:59
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 353429 km
Date: 2022.05.12
Time: 18:02:59
So far I have;
Full scan:
www.Ross-Tech.com
90
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 353442 km
Date: 2022.05.14
Time: 15:32:14
Coding: 000001
Revision: 00002001
Coding: 360200B82C
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 155
Mileage: 353423 km
Date: 2022.05.08
Time: 14:54:23
Coding: 0045F7
Coding: 02512B
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 113
Mileage: 353411 km
Time Indication: 0
Date: 2022.04.23
Time: 21:08:00
Revision: AA001001
Coding: 010000
Coding: 292B07
Coding: 3F04010202
3 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 156
Mileage: 353323 km
Date: 2022.04.19
Time: 07:10:13
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 156
Mileage: 353405 km
Date: 2022.04.21
Time: 15:53:14
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 156
Mileage: 353323 km
Date: 2022.04.19
Time: 07:10:13
Coding: 0000DD
Coding: 00CD077D00
Voltage stabilizer:
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 113
Mileage: 353413 km
Date: 2022.05.05
Time: 20:26:43
Engine running: On
IN ZAS_Te_X: On
Datenfeld: 0
Freeze Frame:
Fault Priority: 7
Fault Frequency: 7
Reset counter: 156
Mileage: 353426 km
Date: 2022.05.10
Time: 20:15:14
Engine running: OFF
IN ZAS_Te_X: OFF
Datenfeld: 0
U140B 00 [008] - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 156
Mileage: 353413 km
Date: 2022.05.06
Time: 19:31:42
Engine running: OFF
IN ZAS_Te_X: OFF
Datenfeld: 1
Cannot be reached
Coding: 00
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 153
Mileage: 353335 km
Date: 2022.04.19
Time: 15:46:44
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 153
Mileage: 353407 km
Date: 2022.04.21
Time: 19:44:08
Coding: 008003
1 Fault Found:
C10C8 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 156
Mileage: 353426 km
Date: 2022.05.10
Time: 18:10:29
Coding: 0010102
Coding: 001F00
Coding: 010000
Coding: 001F00
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 108
Mileage: 353333 km
Time Indication: 0
Date: 2022.04.19
Time: 07:20:04
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 108
Mileage: 353333 km
Time Indication: 0
Date: 2022.04.19
Time: 07:20:36
Coding: 030000
H02 0008
Coding: 1D0000
H02 0008
Coding: 1D0000
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 107
Mileage: 353324 km
Time Indication: 0
Date: 2022.04.19
Time: 07:10:30
Freeze Frame:
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 107
Mileage: 353324 km
Time Indication: 0
Date: 2022.04.19
Time: 07:10:30
Freeze Frame:
Hex Value: 0x0004
Hex Value: 0x0009
Count: 7
Coding: 1090005
Coding: 097205C011
Coding: EE060000
Coding: 662FF2
Coding: 262FF2
Coding: 3F04010202
1 Fault Found:
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 156
Mileage: 353425 km
Date: 2022.05.10
Time: 17:44:41
ROD: EV_BC7.rod
ROD: EV_RGS_L.rod
ROD: EV_RGS_R.rod
