CCM
A4b6
London
Hi,
hoping someone can help me. The passenger footwell was flooded due to blocked drain holes and also due to perished seal around the cabin filter housing. This resulted in the ccm being submerged in water.
I bought a replacement from eBay (same ccm model number 8E0959433BD) plugged it in and found the front electric windows worked, the rear doors locked and the mirrors could be adjusted. However, the mirrors would not fold in, the front doors would not lock, the boot would not open and the fuel flap would not open. Programming it has not helped. Thinking I had purchased a dodgy ccm I bought another one from eBay and found it behaved in exactly the same way. The pins on the connector block are clean.
Does anyone have ideas what could be causing this?
May need vin matching in adaptation.
Thanks for your response.
I believe that was done by the guy that came to program it, I have pasted below the report:
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.9.0.2 (x64) HEX-V2 CB: 0.4555.4
Data version: 20210903 DS330.0
www.Ross-Tech.com
VIN: WAUZZZ8E94A273548 License Plate:
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAUZZZ8E94A273548 Mileage: 109260km-67891miles
Address 01: Engine Labels: 06B-906-018-AVJ.lbl
Part No SW: 8E0 909 518 AS HW: 8E0 909 018 A
Component: 1.8L R4/5VT 0003
Coding: 0011511
Shop #: WSC 63351 000 00000
VCID: 015F83DC9D1F5B93A8F-5160
VINID: 9D196AAAA2152444421C3144209196FCFF
No fault code found.
Readiness: 0110 1001
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517
Component: ABS/ESP front 4529
Coding: 04475
Shop #: WSC 06435
VCID: 6597B74C6C7797B3347-51CE
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
35-10 - - - Intermittent
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AD
Component: A4 Klimaautomat 1324
Coding: 00000
Shop #: WSC 63351
VCID: 6393A9546243E983DA3-5160
4 Faults Found:
01272 - Positioning Motor for Central Flap (V70)
41-00 - Blocked or No Voltage
01809 - Actuating Motor for Temperature Flap; Left (V158)
00819 - High Pressure Sensor (G65)
07-10 - Signal too Low - Intermittent
01330 - Central Control Module for Central Convenience (J393)
49-10 - No Communications - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 F
Component: int. Lastmodul RDW 0517
Coding: 00011
Shop #: WSC 63351
VCID: 3537270C9C572733447-4B00
5 Faults Found:
01332 - Door Control Module; Passenger Side (J387)
01333 - Door Control Module; Rear Left (J388)
01334 - Door Control Module; Rear Right (J389)
01336 - Company Data Bus for Comfort System
80-10 - Single-Wire Operation - Intermittent
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 J
Component: Airbag 8.4EP 1002
Coding: 0010602
VCID: 3E253820AC61E46B95D-5184
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 S
Component: Lenksáulenmodul 0611
Coding: 01011
Shop #: WSC 63351
VCID: 43D349D4C2838983FA3-4B00
1 Fault Found:
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 950 NX
Component: KOMBI+WEGFAHRS. RB4 D42
Coding: 00401
Shop #: WSC 00001
VCID: 0C41A2E8AF5D06FBCB9-5184
WAUZZZ8E94A273548 AUZ6Z0D0043875
3 Faults Found:
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0704
Coding: 00001
Shop #: WSC 00000
VCID: 6B83C1748A93A1C3623-5118
1 Fault Found:
01462 - Anti-theft alarm ultra sonic Sensor (G209)
53-10 - Supply Voltage Too Low - Intermittent
Address 46: Central Conv. Labels:. 8E0-959-433-MIN.clb
Part No: 8E0 959 433 BD
Component: Komfortgerát TBF 1310
Coding: 05871
Shop #: WSC 63351
VCID: 74B1DA08D7AD7E3BB39-4B00
Subsystem 1 - Part No: 8E2959802
Component: Tõrsteuer.FS BRM 0204
Subsystem 2 - Part No: 8E2959801
Component: Tõrsteuer.BF BRM 0204
4 Faults Found:
01811 - Supply Voltage for Door Controller; Drivers Side (J386)
37-00 - Faulty
00941 - Exterior Mirror Retract Motor; Driver Side (V121)
37-00 - Faulty
01812 - Supply Voltage for Door Controller; Pass. Side (J387)
37-00 - Faulty
00942 - Exterior Mirror Retract Motor; Passenger Side (V122)
37-00 - Faulty
Address 55: Headlight Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00060
Shop #: WSC 63351
VCID: 04518AC8873D4EBB839-4B5C
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 195 M
Component: symphony II NP2 0410
Coding: 01200
Shop #: WSC 65536
VCID: 313F131C680F0B1318F-5066
1 Fault Found:
00466 - Control Module for Steering Column Electronics (J527)
49-00 - No Communications
End----(Elapsed Time: 05:22, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
Sent from Mail for Windows 10
Tuesday,18,January,2022,19:20:59:25881
www.Ross-Tech.com
67 69 75 76 77
Coding: 0011511
Coding: 04475
Shop #: WSC 06435
Coding: 00000
Shop #: WSC 63351
2 Faults Found:
Coding: 00011
Shop #: WSC 63351
Coding: 0010602
Coding: 01011
Shop #: WSC 63351
Coding: 00401
Shop #: WSC 00001
Coding: 00001
Shop #: WSC 00000
Coding: 05871
Shop #: WSC 63351
4 Faults Found:
37-00 - Faulty
37-00 - Faulty
37-00 - Faulty
37-00 - Faulty
Coding: 00060
Shop #: WSC 63351
Coding: 01200
Shop #: WSC 65536
End----(Elapsed Time: 05:08, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
Why didn't the coding person look into these issues for you?
He was going to but now he is uncontactable. He did program the key so at least the key switch the alarm on and off. But stuck with the other issues.
It's something I can look to fix for you, chargeable of course, whereabouts in town are you?
Greenford. Is it a programming issue or do you think there are other issues causing this?
Couldn't possibly say as it needs visually checking & diagnostically.
Not the 1st time I've repaired this fault.
Not sure if it is because I am new on here but when I click on the mail icon it doesn’t give me the option of pm’ing anyone. Are you able to pm me so we can discuss further? Thanks
If it's to come out & repair, then WhatsApp me 07974994143, but not if it's a DIY question.
982
n30
699
13
