stock amp question, wire thickness?
craigy
bristol
HI people,
I'm thinking of upgrading the rear amp in my 56 plate, not thinking of anything super high power i just want to run a larger sub, what gauge is the stock amp power wire?
as if possible i would like to use that but obviously if i can't no big deal, the audio wiring is already there so i would only need to route a power line but it i can make it as easy as possible that would be grand as i would like to just make a custom loom that is plug and play to the oem wiring
im currently using the stock amp to run the rear speakers and a VIBE SLICK CBR12 and tbh its doing a good job ohm rating is matched so that's not an issue im not looking for maga bass just something better than that pathetic 6.5in stock sub and for an amp i was thinking of getting one of the vibe amps since they seem pretty good and compact so i could fit it in the stock sub location but would require 8/10 gauge wire
thanks in advance
548
982
858
